Question about B16B
I have a friend who just got a B16B for his 98 Civic. I was looking at the engine and it does not have a Vtec oil pressure/ground sensor plug. Is this engine supposed to be like this? This is the 1st time I've seen a B16B in person so I'm not familiar with it.
On any other Vtec, B-series engine Ive seen, the Vtec pressure is next to the Vtec celinoid. There is not even threads for this sensor to screw into.
Its a jdm motor correct? Some or all jdm motors dont have the vtec switch becuase the ecu doesn't look for it.
So if your bud is using the jdm ecu I think youre ok, if he gets a chipped ecu (best way to go imo) you will have to get the switch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan »</TD></TR><TR><TD CLASS="quote">Its a jdm motor correct? Some or all jdm motors dont have the vtec switch becuase the ecu doesn't look for it.
So if your bud is using the jdm ecu I think youre ok, if he gets a chipped ecu (best way to go imo) you will have to get the switch.</TD></TR></TABLE>
Yes it JDM. Thanks for the info. His wiring is a mess and I was trying to troubleshoot some problems for him.
Dead CIVIC
Jul 13, 2008 01:16 PM
89sparks
Sep 4, 2007 06:35 PM
