bleed clutch when replacing clutch before swap?
Old Apr 29, 2003 | 05:38 PM
TheMostSadistic's Avatar
Default bleed clutch when replacing clutch before swap?
Hey guys, when I get my motor swap (gsr into cx), I plan on replacing the clutch while the motor is out of the car. When I install the motor afterwards, will the clutch pedal be limp and will I have to bleed it? Also, what is the best possible way to bleed the clutch? Thanks
Old Apr 29, 2003 | 05:48 PM
JDMH22HATCH's Avatar
Default Re: bleed clutch when replacing clutch before swap? (TheMostSadistic)
Yes, bleed the clutch thuroughly after the swap. Actually, I would suggest bleeding it all the way to get new fluid throughout the line. Best way to do this is get someone to pump the clutch pedal quickly and then hold it to the ground while you use an 8mm wrench to open the bleeder on the clutch slave. Repeat this process and keep filling the clutch master slave cylinder until there is a constant stream of fluid with no sputtering. Good luck with the swap.
Old Apr 29, 2003 | 06:08 PM
Default Re: bleed clutch when replacing clutch before swap? (JDMH22HATCH)
awesome, thanks for the reply. Should be getting my car this week, 93 cx hatch, then its time to save for the motor. every time I see an h22a in an engine bay its so tempting.
Old Apr 29, 2003 | 06:10 PM
sorry but by 'sputtering' do you mean no bubbles in the line? also, what do you mean by bleeding it all the way. Also, when I remove the old motor in the car will the clutch pedal go limp? Thanks
Old Apr 29, 2003 | 06:18 PM
When you bleed the clutch at the clutch slave, the fluid will come out sputtering the first few times because of the bubbles in the line. Once there are no air bubbles, the fluid will shoot out in a constant stream. And once you pull the motor out, the pedal will go limp since the rod from the clutch slave will not be pushing on the clutch fork.
Old Apr 29, 2003 | 06:25 PM
worrrd I get it now, thanks man!
Old Apr 29, 2003 | 06:56 PM
If you need help, don't be afraid to ask. Oh yeah, here's a little tease for your previous comment. HeHe!
Old Apr 30, 2003 | 03:31 AM
::droooooooool:: is all I can say about the picture, all that's holding me back is the cout mount, and mounting the shifter I know I probably sound lazy, are those factors of the swap difficult? Thanks for the help man. Peaceeee
Old Apr 30, 2003 | 05:01 AM
VTECVillain's Avatar
Anytime to introduce air into the hydro lines whether you open the bleeder screw or disconnect the lines, the pedal is going to go limp because it looses pressure. What he means by completing bleeding the system is to work all of the old fluid out while you're putting new fluid in and then bleed out any air.
aznpreludeSH
Dec 5, 2008 03:54 AM
integraracing91
Apr 4, 2008 11:07 AM
nonvtec92
22
May 7, 2007 05:11 PM
redpeppers
May 17, 2006 04:29 PM
H22A EG6
Sep 2, 2004 07:22 PM
