ngk coppers, 2 heat ranges colder, h22, need part #
Old Apr 24, 2003 | 11:16 AM
fastludeh22's Avatar
Default ngk coppers, 2 heat ranges colder, h22, need part #
is 2 heat ranges good enough for 25 psi/80 shot? what about everyday driving at 15 psi.
Old Apr 25, 2003 | 07:23 AM
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (fastludeh22)
anyone?
Old Apr 25, 2003 | 07:34 AM
b18bturbo's Avatar
use part number r5671a number 8 or number 7 they are the NGK racing plugs cost about 2.59 a plug
Old Apr 25, 2003 | 09:03 AM
GraphiteAccord's Avatar
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (b18bturbo)
i bought heat range 7 because it was hard enough to find locally, 8's were impossible. NGK bkr7e-11's or ngk BCPR7e-11 would work well also...all copper...
Old Apr 25, 2003 | 09:12 AM
XES's Avatar
XES
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (GraphiteAccord)
I use NGK ZFR7F11 plugs for the 24psi runs and the daily driving. They work great and are used in my H23 everyday (and would be fine for your application).
I also have some NGK V-power 8's (R5672A-8)...but they are not currently in use.
Old Apr 25, 2003 | 09:14 AM
Smurfylude's Avatar
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (XES)
who sells these? I need a set
Old Apr 25, 2003 | 09:15 AM
XES's Avatar
XES
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (Sushi X [TCL])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushi X &raquo;</TD></TR><TR><TD CLASS="quote">who sells these? I need a set</TD></TR></TABLE>
Which ones?
Old Apr 25, 2003 | 09:17 AM
Smurfylude's Avatar
NGK ZFR7F11 plugs
Old Apr 25, 2003 | 10:28 AM
XES's Avatar
XES
Do a search online...I get mine at AutoValue stores in Canada.
Old Apr 25, 2003 | 10:34 AM
Scott - 93HB Si's Avatar
XES?
Where in Canada do you get them? Like Crappy Tire? or UAP? Do you have to order them?
With that much boost you only need 7's???
Old Apr 25, 2003 | 11:42 AM
XES's Avatar
XES
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (Scott - 93HB Si)
Call around...most people who stock NGK can get these plugs in (they may have to be ordered). As for using 7's...the burn line, etc. on the plug is perfect with 7's, and not perfect with 8's.
Old Apr 25, 2003 | 02:15 PM
inspyral's Avatar
http://www.clubplug.net
I think they're in Canada too.
Old Jun 20, 2003 | 08:43 AM
Smurfylude's Avatar
Default Re: ngk coppers, 2 heat ranges colder, h22, need part # (inspyral)
Does anyone know which is better to get?
NGK r5671a number 8 or number 7
Here is my set up
Mild Port and polished H22A4 head
Ferrea valves, retainers & dual springs
JDM H23 vtec block and crank sleeved by Golden Eagle
JE 10:1 forged pistons 87mm with Rings(with the H23 compression comes to about 10:6)
Crower forged H23 Rods
Cometic .4 head gasket (lowered the Compression to 10.2 maybe?)
Maxrev Turbo Kit
T3/T04E T-601 Turbo
MSD Blaster SS
STR Hi-flow Fuel rail
AEM Fuel filter
B&M Fuel pressure regulator
Walbro 255 LPH intank fuel pump
Precision Turbo 78lbs/hr Injectors
Hondata IM gasket
Hondata 2B
OBDII -&gt; OBDI ECU harness
P28
Mugen Thermostat
Mugen fan switch
Old Jun 20, 2003 | 11:57 AM
Smurfylude's Avatar
bump Help?
Old Jun 20, 2003 | 12:31 PM
civperc's Avatar
Default Re: (Sushi X [TCL])
haha dude, wait a little longer than a couple hours for some replies
rdeezy78
Oct 2, 2007 05:17 PM
powerdbygarrett
Jul 27, 2007 09:43 AM
ghostrider1
Jan 4, 2007 06:04 PM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
dvp95
May 22, 2003 07:50 AM
