arp head stud install question, very simple
Old Apr 23, 2003 | 04:37 AM
trbob16a's Avatar
Default arp head stud install question, very simple
The studs are threaded at both ends obviously. On one end in the shaft right before the threads the stud bubbles out and then the threads start. Does the side that bubbles go down and to the block, or up at the head where the nut screws on.
Old Apr 23, 2003 | 04:41 AM
DaveF's Avatar
Default Re: arp head stud install question, very simple (trbob16a)
doesnt the nut only screw on one side....but the part that bubles out goes into the block
Old Apr 23, 2003 | 04:43 AM
trbob16a's Avatar
Default Re: arp head stud install question, very simple (2.2Lcivic)
well i had that right... as I was taking it apart I was thinking maybe that bubble was preventing my head from tightening down because the headgasket blew out at idle. on to more brainstorming, thanks
Old Apr 23, 2003 | 04:48 AM
boostaholic's Avatar
Did you get a chance to check your dowels that sit between the block and head? If you shaved both the head and block, you probably have to shave the dowels down. For the studs, the nuts will only thread on one side and the longer section of threads should go into the block.
Old Apr 23, 2003 | 04:54 AM
trbob16a's Avatar
Default Re: arp head stud install question, very simple (boostaholic)
ok thanks guys, I'll shave down the dowels and use copper spray this time. I appreciate the fast replies. I didn't check the nuts I was just brainstorming in the shower and thougth maybe I had the studs in upside down..
GSR_hatch936
May 27, 2008 06:09 PM
Peter Brady onlyonweekndz
Dec 4, 2007 10:22 AM
80884
Dec 8, 2004 04:09 PM
clsmooth
Aug 24, 2003 06:47 PM
avividmemory
Dec 15, 2002 12:19 PM
