stripped arp head stud or block?
Old Dec 2, 2007 | 04:36 PM
Peter Brady onlyonweekndz's Avatar
Default stripped arp head stud or block?
i was torquing my headstuds down and it felt like one stripped. i kept torquing it and it went to spec..has anyone done this before? idk if i screwed something up or im just paranoid...
Old Dec 2, 2007 | 04:45 PM
philafelman's Avatar
Default Re: stripped arp head stud or block? (Peter Brady onlyonweekndz)
remove the bolt and inspect the threads....why did it feel stripped if it torqued down to spec?
Jaker's Avatar
Though there's a slim to none possibility that the stud stripped, more likely if anything stripped, its the block. However, when you're torquing the head studs, what might feel like a stripped fastener, is more likely the washers between the nut and the head that has scooted around a bit.
I've felt that uneasy sensation a bunch of times in the past when torquing headstuds/bolts and I've never stripped anything.
Old Dec 2, 2007 | 05:07 PM
Default Re: stripped arp head stud or block? (Jaker)
yea, i was thinking that could be a possibility.. i wouldnt think the block would be stripped cause it was only 69ft pounds i torqued it to...
Old Dec 2, 2007 | 08:36 PM
could i reuse the head gasket if i took off the head to check it out?
Old Dec 3, 2007 | 07:25 AM
hybrid_KJ's Avatar
If the threads started to pull out of the block you would not have hit 69 ft-lbs. You are fine, if you really want to recheck just go and torque each nut to 69 ft-lbs angain. That "slip" you probably felt was the nut and the washer slipping on each other. If you ever assemble again just make sure you lube the underside of the nut and the washer and it will torque more smoothly.
Old Dec 3, 2007 | 08:11 AM
mike93eh2's Avatar
ive stripped 5 holes in the block before with not much torque..
timesert is your friend...they even make kits specifically for doing headstud holes in honda blocks. stronger than ever!
http://www.timesert.com/html/u....html
the kit is badass and easy to use. ive boosted on 5 repaired holes before with zero problems. but it is expensive..
Old Dec 3, 2007 | 08:30 AM
Turbo-charged's Avatar
Default Re: (mike93eh2)
our timesert kit paid for its self in the first month of having it. our local machine shop even sends us blocks to do. the aluminum in the block isnt very forgiving, and a lot of time when machine shops do boring/honing/sleeving/decking etc. they get a bunch of crap in the head bolt holes and they dont clean them out which can screw everything up as well.
ERL can do metal inserts sort of like time serts but way beefier, i wish i could remember what they call them. i have them in my block, they work great.
Old Dec 3, 2007 | 11:33 PM
Default Re: (Turbo-charged)
well, block is fine..it was the washers slipping... i was just being **** about it.. thanks
Old Dec 4, 2007 | 06:38 AM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">they get a bunch of crap in the head bolt holes and they dont clean them out which can screw everything up as well.</TD></TR></TABLE>
[Test] tube cleaners FTW Chop off the circle on the end, put it in your electric drill, then fill said hole with degreaser.
Old Dec 4, 2007 | 07:16 AM
THEDirtyDseriesWOOT's Avatar
I have stripped 2 ARP headstuds before..
from reusing them aobut the third time i change ahead gasket it always seems like 1 of them is stripped.. the actual nut that fgoes on top the thread strip on thise nott he stud.. but yah .. thats my opinion on the subject
Old Dec 4, 2007 | 10:22 AM
Default Re: (THEDirtyDseriesWOOT)
i got the studs for an ls and when i put them on the ones in the middle that are supposed to be longer came up short when i put the head on. so i had to back them up a little the make the nut flush with the stud..
willard steen
Apr 5, 2016 12:22 AM
DC2-ProdUcTiOnS
Oct 27, 2011 02:07 PM
Murderface95
Nov 11, 2009 09:54 PM
The93egg
Mar 1, 2009 11:02 AM
80884
Dec 8, 2004 04:09 PM
