LCA shock bolt solution...
Old Apr 22, 2003 | 09:12 PM
Mikey's Avatar
Default LCA shock bolt solution...
My friend and I were putting coilovers on a Civic a few weekends ago. We ran into the infamous stubborn/frozen LCA bolts.
We ended up welding a huge nut on the small LCA nut. Here's some pics:
I know I didn't break new ground here, but this is an old technique to remove stripped bolts that became very usefull. I'm not guaranteeing this will work, but it did for us.
Old Apr 25, 2003 | 10:56 AM
PnX-R's Avatar
Default Re: LCA shock bolt solution... (Mikey)
So you welded a bigger nut on top of the small one??
Old Apr 25, 2003 | 08:47 PM
Mikey's Avatar
Default Re: LCA shock bolt solution... (PnX-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnX-R &raquo;</TD></TR><TR><TD CLASS="quote">So you welded a bigger nut on top of the small one??</TD></TR></TABLE>
Jes.
The heat from the welding will transfer to the whole bolt thus expanding the bolt slightly-crushing the crap that tends to seize it up. When it cools, the bolt should be ready to be wrenched off.
EFstyle
23
Jan 27, 2007 10:49 PM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
gowyeng
Jun 20, 2004 12:02 AM
Layziebtnh055
May 14, 2004 06:42 AM
GoQkRaCeR
Apr 24, 2004 05:40 PM
