first day of boost, slight oil leak problem, seal it?
i finnally drove my homemade turbo DOHC ZC, hit 6 PSI, but once i got back i let it idle and oil was dripping like it was coming from where the oil feed line goes into the turbo, i cant tighten it anymore, so i bought this stuff called liquid seal, it can take up to 500 degrees, would it be ok just to put this around the seal to ensure no more leaking>?
I know the feeling. Since the day I brought my integra home, its been slowly leaking oil from the same location. I am having it fixed though very soon when i bring it in to have my new block put in.
haha ya, but mines not a little, there is about a 6 inch diameter puddle under my car, its kinda a big deal, and i used teflon tape at all connections, that isnt my problem
Have you ever put teflon tape in oil and see what happens to it ?
It melts .
Go and buy permatex part#56521 make shure the parts are realy clean and apply.
The only thing is you have to whait over night for it to dry and then your good to go.
It melts .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">Have you ever put teflon tape in oil and see what happens to it ?
It melts .
The only thing is you have to whait over night for it to dry and then your good to go.</TD></TR></TABLE>No ****? I must use some really good stuff then because in all my 10+ years of using that stuff I have never had that problem.
It melts .
marcj
Oct 6, 2008 12:16 PM
Snafu-Si
Jan 22, 2005 10:21 AM
