Pics of my homemadeturbo on 99 Si!
Modifications:
T3 turbo from a Nissan (.48/.60)
Maxrev manifold
Tial wastegate 6.5psi spring
2.5" downpipe with cutout for open downpipe
2.0" JCWhitney pipes to IC, 2.25" from IC to TB
Homemadeturbo.com Tyris intercooler
HKS BOV
Homedepot Reducers (fit great! $3.49 each!)
Stainless -3AN line
Custom 2.5" mandrel bent exhaust to Magnaflow muffler
DSM 450cc injectors, DSM resistor box
Interior:
Apex'i VAFC controlling the fuel (set to -38 across the board). NOTE: STARTS UP BEAUTIFUL, INSTANTLY. Transition in and out of boost is great, no bucking either!!!
Autometer CF boost gauge, A/F, and full sweep elec fuel press
SRR pedals
Questions? Comments?
looks really good
. What kind of numbers are you putting out? I dont see many homemade setups on 99 si's but yours is good. Let us know what kinda times you get and again good job
Honestly I have no idea. I just started driving it today. I have a slight oil leak at the T. My T on the block has the oil feed at the top, and the oil pressure sensor at the bottom. The rubber "hat" of the sensor just barely clears, and the oil is seeping out of the "hat". So i'm going to try and extend the wire and cover it up more and hope that fixes it.
I just took these pics with the flash on, cuz it's night out, and it looks really dirty. But it's actually pretty clean!
Im guessin around 210 crank horsepower? I don't know. I want an Apex'i Rev/Speed. Oh yeah I have an HKS turbo timer i need to hookup.
did you fix the oil leak at the t fitting ? If not the fix is you have to go buy permatex part#56521 its the only thing i found that works . the reason must be because the oil pressure sender has metric pipe threads and your t fitting has
1/8" ntp threads so they dont seal so well. make shure the parts are clean and it must sit over night before you can use it .
i was expecting a ghetto turbo set-up from the name of your title . turned out pretty good
, what did the final cost end up being ?
I will get some finer mesh. I have an HKS filter i want to put on, but i'll worry about it later, cuz i have no pipes.
I will do a write and prices and stuff.
As far as the oil leaking at the pressure sensor. I think i gotta take it off, reclean it and put some permatex on it. Cuz its still leakin there. What a bitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
As far as the oil leaking at the pressure sensor. I think i gotta take it off, reclean it and put some permatex on it. Cuz its still leakin there. What a bitch.</TD></TR></TABLE>
I might be misunderstanding you... but have you considered getting a bspt adapter?
0ptimus prime
Apr 6, 2005 08:44 PM
