wide band oxygen sensor ?
Old Apr 17, 2003 | 10:20 AM
respectblades's Avatar
Default wide band oxygen sensor ?
ok wide band oxygen sensors can be used on stock ecm' programs.... true or false....
and i also heard that the stock o2 sensors cant give an accurate fuel reading during dyno's
please give me your input
Old Apr 17, 2003 | 10:22 AM
psi420's Avatar
False
Accurate enoguh for your ecu, not as good for tuning.
Old Apr 17, 2003 | 10:25 AM
Default Re: (psi420)
well i just called hondata
745 is the price for their wide band...
i almost fell over...
do any other companies made wide band oxygen sensors?
Old Apr 17, 2003 | 10:27 AM
Spade's Avatar
Default Re: (respectblades)
They came on the VX and HX stock.
Old Apr 17, 2003 | 10:29 AM
psi420's Avatar
Default Re: (Spade)
I know they are 5 wire, but are they a true wideband?
I have one or two from Honda's and an extra VDub one laying around.
Old Apr 17, 2003 | 10:49 AM
Blaze45's Avatar
Brrraaaap!
Are you serious that they came stock? Are you sure???
Blaze
Old Apr 17, 2003 | 01:07 PM
joe_bocc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades &raquo;</TD></TR><TR><TD CLASS="quote">do any other companies made wide band oxygen sensors?</TD></TR></TABLE>
FJO and Tech Edge are two companies that make wide band O2 kits.
Old Apr 17, 2003 | 01:25 PM
T3's Avatar
T3
Default Re: (joe_bocc)
Bosch
Old Apr 17, 2003 | 02:05 PM
KENetics1's Avatar
Default Re: (Blaze45)
Listen to spade he knows what he's talking about. I know for sure they came on the vx but I never knew they did on the hx. You can tell too because the price on these 02 sensor from honda are more than all the others.
Old Apr 17, 2003 | 02:38 PM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Are you serious that they came stock? Are you sure???
Blaze</TD></TR></TABLE>
RSZero1 put a Y8 in a HX last weekend. The O2's are 5 wire widebands and throw a code with the EX ECU. He had to resort back to the HX ECU until this weekend.
Old Apr 17, 2003 | 02:59 PM
RSZero1's Avatar
Default Re: (Spade)
Spade you da man...now anyone wanna buy my wideband when i'm done? lol
Old Apr 17, 2003 | 06:19 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (RSZero1)
Why did honda put a wideband into thier car?
Blaze
Old Apr 18, 2003 | 06:48 AM
Spade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Why did honda put a wideband into thier car?
Both the VX and HX are designed as economy cars. Well, more than any of the other Civics. They have EGR valves and run leaner than regular civics so they need more capable O2 sensors to properly measure the air/fuel ratio.
Old Apr 18, 2003 | 08:36 AM
Stew Pidasso's Avatar
Default Re: (Spade)
So can you wire this stock wideband to some display to monitor your a/f ratio ? How would it work with Hondata?
Old Apr 18, 2003 | 12:10 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (Stew Pidasso)
Yeah anyone know if it would work with ZDYNE as well?
Blaze
Old Apr 18, 2003 | 12:56 PM
Spade's Avatar
Contact each company and ask them. Cannot hurt any.
Old Apr 18, 2003 | 01:20 PM
vactor's Avatar
the wideband SENSOR connects to the necessary wideband CONTROLLER, and the output voltage of the CONTROLLER goes to the stock O2 sensor plug on the harness, then you program the hondata as to the voltages the controller puts out for the lambda values, and then you can datalog wideband ratios with hondata, or use the programmer/romulator to run autotune with Hondata.
Old Apr 18, 2003 | 01:29 PM
LshatchTurbo's Avatar
New User
Default Re: (vactor)
Got a Geniune honda VX o2 sensor for sale. Check my SIG
Old Apr 18, 2003 | 05:46 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (lshatchturbo)
So does anyone know how accurate these things are? and what is it that you have to hook it up to?
tia
Blaze
Old Apr 18, 2003 | 06:50 PM
New User
https://honda-tech.com/zerothread?id=477769
Old Apr 18, 2003 | 07:28 PM
Blaze45's Avatar
Brrraaaap!
thanks
Blaze
Old Apr 19, 2003 | 07:41 PM
NonovUrbizniz's Avatar
Loved
search for diy wideband o2 sensor on google... you'll thank me OVER AND OVER again...
They make circut boards and part kits you can buy for like 40 bucks and solder together yourself then all you need is a wideband o2 sensor (yes the honda will work as well as a couple others)
How accurate are they?.... they give a TRUE a/f ratio... most good shops use a wideband o2 in conjunction with their dyno in order to PROPERLY tune the engine.
the voltage output is variable and it give a VERY accurate reading assuming it's functioning in new condition.
Old Apr 19, 2003 | 07:52 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (NonovUrbizniz)
thankyou thankyou thankyou thankyou
thanks
Blaze
Old Apr 22, 2003 | 07:30 AM
Screamer's Avatar
https://honda-tech.com/zerothread?id=483099
If anyone is interested.
Old Apr 22, 2003 | 02:51 PM
Loved
No Problem!
vtec.dc2
Dec 12, 2006 04:54 PM
ruthlesstyper
Dec 3, 2004 04:24 AM
birz
Jan 14, 2004 04:39 PM
integlspwr2k
Dec 27, 2003 07:37 PM
RTW DC2R
Jul 16, 2003 05:42 AM
