What all will I need with Hondata set up??
Old Apr 17, 2003 | 09:23 AM
civicqm's Avatar
Default What all will I need with Hondata set up??
I was on the hondata web page and I am kinda confused as to what all I will need for my setup. I have a 99 Civic Si with A drag turbo kit and I will be building the motor to run about 15 lbs of boost. If you guys could give me a layout of what I need that would be great.
Old Apr 17, 2003 | 09:51 AM
g2turbo's Avatar
Default Re: What all will I need with Hondata set up?? (civicqm)
s200 with boost
550-780cc injectors
intank fuel pump (255)
thats about it
Old Apr 17, 2003 | 09:54 AM
DeepSi's Avatar
Default Re: What all will I need with Hondata set up?? (g2turbo)
The above plus....
GM 3 bar map sensor
OBD2-OBD1 Conversion harness
Old Apr 17, 2003 | 10:43 AM
ladysman's Avatar
Default Re: What all will I need with Hondata set up?? (DeepSi)
And Hondata socketed ECU.
Old Apr 17, 2003 | 10:55 AM
SOHC_power's Avatar
Default Re: What all will I need with Hondata set up?? (ladysman)
If you are just getting the s100b do you still need the OBD2-OBD1 harness?
Old Apr 17, 2003 | 11:04 AM
metal-x's Avatar
Default Re: What all will I need with Hondata set up?? (SOHC_power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_power &raquo;</TD></TR><TR><TD CLASS="quote">If you are just getting the s100b do you still need the OBD2-OBD1 harness?</TD></TR></TABLE>
yup
Old Apr 17, 2003 | 04:02 PM
krazy's Avatar
Default Re: What all will I need with Hondata set up?? (metal-x)
a 1:1 rising fuel pressure regulator. i dunno if the stock one is this, but the aeromotive one is more than acceptable.
krazy
Old Apr 17, 2003 | 11:34 PM
civicqm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">And Hondata socketed ECU.</TD></TR></TABLE>
Does this mean a whole new ECU??
Hey thanks for all your help guys, does anyone know how much this will all cost?? I am weighing out the options between this and the AEM. Just trying to figure out numbers....
Old Apr 17, 2003 | 11:52 PM
95c1v1cs1's Avatar
No it means send your ecu in to get socketed so that you can put your hondata chip in it.
Old Apr 18, 2003 | 05:49 AM
ekb18c's Avatar
You will need a obd1 ecu. You can not use your obd2 ecu for hondata.
Here is what you need
s100b or s200b
obd2 to obd1 conversion harness
obd1 ecu that is socketed for hondata.
Tuning
Old Apr 18, 2003 | 07:59 AM
DLB1994's Avatar
Default Re: What all will I need with Hondata set up?? (ekb18c)
get a p28 ecu
Old Apr 18, 2003 | 12:24 PM
civicqm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">You will need a obd1 ecu. You can not use your obd2 ecu for hondata.
s100b or s200b
Tuning
So how much am I looking at to do all of this?? The s200 w/ boost and then all the things that you listed...Thanks
Old Apr 18, 2003 | 12:33 PM
ekb18c's Avatar
check your IM's
Old Apr 20, 2003 | 05:37 PM
Smitdog's Avatar
http://www.sgt-racing.com
jonesEK
Jun 2, 2011 05:30 PM
XxRoCkMaNxNEOxX
Oct 15, 2004 12:16 PM
Import_Fan
Sep 13, 2004 03:04 PM
cyan1de
Nov 23, 2001 10:20 AM
