Fuel Pressure Regulator Fitting...Drag Gen.
Hi,
A couple of friends of mine are doing an install of a drag gen turbo kit on a 96 spec JDM ITR.
We have a problem with the FMU / "Boost dependant Fuel Pressure Regulator"
This item is a round blue disc like piece. We need to know which of the male type connectors is the "IN" and "OUT".
Therefore which will connect to the standard Fuel Pressure Regulator and which will connect with the Intake Manifold (vacuum).
There is absolutely no indication on the instructions and either on the FMU.
Please Help guys !!
Thanking you,
Eric
Please Help guys !!
Thanking you,
Eric
