Difference between an FMU and FPR????
Old Dec 5, 2002 | 02:11 PM
superduperman's Avatar
Default Difference between an FMU and FPR????
What's the difference and purpose for these two when it comes to turboed cars. Do they go hand in hand or is one serve the same purpose better than the other?? Thanks for any of those whom reply
Old Dec 5, 2002 | 02:22 PM
Ben Huynh's Avatar
Default Re: Difference between an FMU and FPR???? (superduperman)
What's in a name?
An FPR normally refers to an adjustable fuel pressure regulator.
An FMU normally refers to a boost dependent fuel pressure regulator.
Old Dec 5, 2002 | 02:34 PM
Smashback's Avatar
and of course there is the adjustable FMU like the cartech
Old Dec 5, 2002 | 02:38 PM
KStuned's Avatar
Default Re: Difference between an FMU and FPR???? (Hatchblack)
An FMU raises fuel pressure based on boost, for example a 12:1 fmu would raise fuel pressure 12psi for every 1 psi of boost, that way the fuel pressure is only risen while boosting.
A fuel pressure regulator adjusts the fuel pressure at idle, and driving around, all throughout the rpm range, just not dependent on boost. Of course as manifold vacuum decreases the fuel pressure rises.
Old Dec 5, 2002 | 02:55 PM
Default Re: Difference between an FMU and FPR???? (Hondaddict)
THanks for the replys everyone. But i was more curious to know, which one do I use to adjust my fuel pressure at a certain boost. Let it be for driving or at idle. Thanks.
Old Dec 5, 2002 | 03:46 PM
foesicks's Avatar
What about the 1:1 aeromotives or something of that sort, what do people use them for?
astig* DC2
Jul 13, 2005 02:04 PM
scartail
Oct 12, 2004 11:53 AM
JDMH22
Feb 23, 2004 12:30 AM
b16ahybrid
Nov 28, 2002 07:51 PM
CiViCMiNDed
May 22, 2002 11:14 PM
