oil drain fitting really close to my downpipe,will it melt?
Old Apr 13, 2003 | 06:54 PM
civicguy's Avatar
Default oil drain fitting really close to my downpipe,will it melt?
just wondering before i start running the car
Old Apr 13, 2003 | 06:58 PM
agturbo's Avatar
Default Re: oil drain fitting really close to my downpipe,will it melt? (civicguy)
If its rubber, not a good idea, try using a steel braided line...
Old Apr 13, 2003 | 07:51 PM
inspyral's Avatar
Default Re: oil drain fitting really close to my downpipe,will it melt? (agturbo)
My rubber drain line was about 1/2-3/4" from my dp, and it never melted. You might want to put some fire sleeve over it, though. My new drain line is made from EARL's Perform-o-flex and Swivel Seal fittings.
Old Apr 13, 2003 | 08:14 PM
turbod16y8's Avatar
Default Re: oil drain fitting really close to my downpipe,will it melt? (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">My rubber drain line was about 1/2-3/4" from my dp, and it never melted. You might want to put some fire sleeve over it, though. My new drain line is made from EARL's Perform-o-flex and Swivel Seal fittings.</TD></TR></TABLE>
Same HERE!!
Old Apr 14, 2003 | 12:16 AM
GOLDBERG's Avatar
Default Re: oil drain fitting really close to my downpipe,will it melt? (turbod16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">
Same HERE!!</TD></TR></TABLE>
same here
Old Apr 14, 2003 | 09:59 AM
BROOD's Avatar
I use Perform-o-Flex and Ano-Tuff fittings for my drain lines. But extreame heat will still affect the line, you still want to eliminate any direct contact between the drain line and the downpipe.
88crxhfb16
Jun 27, 2005 08:53 AM
civicek00
May 31, 2005 09:38 AM
DEVIN22CBR
Feb 5, 2004 04:08 PM
dualknuttz1
Aug 10, 2003 10:34 PM
D A 9
Jul 27, 2003 05:16 AM
