auto to manual conversion help. pedal asseembly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limoZeen »</TD></TR><TR><TD CLASS="quote">how the **** do you get this thing out of the car? theres 5 nuts (lower) 1 bolt (upper) those are gone, thing doesnt budge.
With lots and lots of cursing and swearing...
Did you disconnect the brake pedal from the master cylinder? You also have to pull the M/C forward into the engine bay, so that the pedal assembly can come free.
You'll also need to remove some the heater piping that is beneath your dash, so that the assembly can pull forward.
</TD></TR></TABLE>With lots and lots of cursing and swearing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limoZeen »</TD></TR><TR><TD CLASS="quote">yeah i missed a nut that had to be removed. also i had to drop the steering column. no way that thing it coming out otherwise
Yes it will come out with the steering column in but its also a bitch to get out, not sure if you have it out yet but there is one bolt under the air duct that you need to get. Good luck, its really a pain in the *** working in that area and not being able to get them out.
</TD></TR></TABLE>Yes it will come out with the steering column in but its also a bitch to get out, not sure if you have it out yet but there is one bolt under the air duct that you need to get. Good luck, its really a pain in the *** working in that area and not being able to get them out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limoZeen »</TD></TR><TR><TD CLASS="quote">yeah its out and the new one is in. i didnt have the pacience to leave the column in, plus its only 6 bolts then it drops.
oh well, least it only has to be done once
Well you can only hope it don't have to be done again, I have heard some breaking over time.
</TD></TR></TABLE>Well you can only hope it don't have to be done again, I have heard some breaking over time.
i did the swap in my 91 crx and i had to tear the dash out for the one bolt i almost gave up but after swearing and bleeding i got it done. i dont ever want to do it again.
Yeah I put CRX Si pedals in my STD hatch for the neutral safety switch. God what a pain. I had the dash off at the time, but still.
I just got done about an hour and a half ago pulling out now my forth pedal assembly I dont think that they are that bad at all. And also you can get them out without pulling the M/C forward or pulling the dash or pulling the sterring column now let alone its much easier to pull it all out but its not necessary at all. I tried to do it with taking out the least amount as possible cause at the time I didnt think that I was going to completely rip my car apart oh how things soon change
civictom
Oct 22, 2004 11:55 AM
