hooked up my manual boost controller and boost gauge today, is this right
Old Apr 10, 2003 | 07:28 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default hooked up my manual boost controller and boost gauge today, is this right
running a 14b turbo on a ZC motor, as far as i can see, theres only one place i could possibly run a line from the 14b, which is from the wastegate actuator, so i ran a vacuum hose from that to the bottom of my boost controller(T setup), then i ran the other line of the controller to the intake manifold, i then ran the clear tubing that came with my boost controller and got the correct end on it so i could put a vacuum hose on it, the i t'd that into the same hose which connects the boost controller to the intake manifold, how does this all sound?
Old Apr 10, 2003 | 07:54 PM
rjardy's Avatar
Default Re: hooked up my manual boost controller and boost gauge today, is this right (Y49CRXSIZC)
Sounds correct. Does the MBC hold boost? as in does it creep? Im thinking about getting the turbo xs dual stage MBC.
Rob
skaraider
Jun 6, 2012 03:26 AM
2ndchirp
May 24, 2009 08:14 PM
99silverbullet
Jan 3, 2004 06:28 PM
buckfittyone
Jul 31, 2003 05:35 PM
austrian type-R
Apr 18, 2002 10:00 PM
