boost line for mbc to thick?
Old Apr 18, 2002 | 09:21 PM
austrian type-R's Avatar
Default boost line for mbc to thick?
How big is the diameter of your boost line from turbo-housing --> manual boost controler --> wastegate? Mine is about 5-6 mm and I think it is too big to adjust the boost accurate. I turn the **** on the manual boost controler (from fully closed) only 20 degrees and the boost is overshooting.
Would some kind of restrictor in the boost source help?
Old Apr 18, 2002 | 09:34 PM
LsTurbo91's Avatar
Default Re: boost line for mbc to thick? (austrian type-R)
*shouldn't have gotten rid of the AVCR* Cough... 6mm sounds about right. I believe 4mm is the small vacuum lines that run through the intake mani.
Old Apr 18, 2002 | 10:00 PM
Default Re: boost line for mbc to thick? (LsTurbo91)
I still have my AVCR, but I turned it off for boost setting. I try the trick with the restrictor for more accurate adjustment with the mbc.
ericstambaugh07
Jun 23, 2007 09:04 AM
ericstambaugh07
Apr 7, 2007 12:45 PM
Meet07
Feb 3, 2004 10:45 PM
boostdB16a
Jul 8, 2003 06:10 PM
