Non-vtec chip in p28 ECU, will it work?
Old Apr 8, 2003 | 04:33 PM
InfamousRS's Avatar
Default Non-vtec chip in p28 ECU, will it work?
Im going to be taking my Vtec head off for a short time. Can I just put a Non-vtec aftermarket chip in my chipped p28? Or can I run a LS head with a Vtec program?
Old Apr 8, 2003 | 05:11 PM
VTECVillain's Avatar
Default Re: Non-vtec chip in p28 ECU, will it work? (InfamousRS)
No
No
Old Apr 8, 2003 | 06:34 PM
InfamousRS's Avatar
Default Re: Non-vtec chip in p28 ECU, will it work? (VTECVillain)
care to explain why?
Old Apr 8, 2003 | 06:49 PM
No
It would be pointless to "chip" a P28 to nonVTEC specs if it were possible. Just get a nonVTEC ECU to run the motor, much simpler and cheaper.
An LS head will not fit a DOHC VTEC block without the reverse mods that it takes for an LSVTEC. I'm assuming that you have a DOHC VTEC motor. It defintely will not a SOHC VTEC block.
[Modified by VTECVillain, 10:49 PM 4/8/2003]
Old Apr 8, 2003 | 06:57 PM
InfamousRS's Avatar
Ummm....I have a B20Vtec. I need to take my built Vtec head off for a short time. Im going to put one of my many LS (b18b) heads on for the time being. Right now I am running my B20Vtec with a Mugen chipped p28 ECU. I do not have a p74/75/06 on hand to run, nor do I want to buy one for the time being. I am just curious how the chipped p28 ecu will run my b20 (with the LS head).
Edit: This will only be for a short time, until I get my new motor/head put together and in my car. At that time I will also be using hondata.
[Modified by InfamousRS, 8:31 PM 4/8/2003]
Old Apr 10, 2003 | 06:51 AM
CHEETAH's Avatar
just groudn your vtec pressure switch wire and leave vtec solenoid wire unplugged ... it'll ahve a code 22 and 21 but it'll still run fine
greg
Old Apr 10, 2003 | 09:26 AM
InfamousRS's Avatar
Default Re: Non-vtec chip in p28 ECU, will it work? (CHEETAH)
Thank you, thats all I wanted to know.
HondaVTEC1993
Engine Management and Tuning
19
Apr 26, 2018 09:02 PM
chope045
Jul 15, 2011 11:20 AM
CRX_RR
Mar 1, 2008 09:54 PM
imskatencrzy
Sep 20, 2006 01:26 PM
Homer_Simpson
Sep 29, 2001 05:01 AM
