how do i get rid of that annoying beeping noise?
Old Apr 8, 2003 | 01:45 PM
jintek's Avatar
Default how do i get rid of that annoying beeping noise?
i mean the chime that beeps when you have your doo open while the key is in the ignition??
Old Apr 8, 2003 | 01:54 PM
Kamin's Avatar
Default Re: how do i get rid of that annoying beeping noise? (jintek)
close the door or take the key out
Old Apr 8, 2003 | 01:58 PM
gogeeta13's Avatar
Default Re: how do i get rid of that annoying beeping noise? (Kamin)
if you dont care about your dome light, glue, strap shut or short-out the switch on your door.
Old Apr 8, 2003 | 02:00 PM
PotatoePAPA's Avatar
There is a fuse you can take out...however as annoying as it is right now, you WILL miss it that time you leave your keys in the ignition I did the same thing for a while....hated it.
Old Apr 8, 2003 | 02:02 PM
fowler!'s Avatar
Default Re: how do i get rid of that annoying beeping noise? (ActionJackson)
Disconnect that plug below your seat.
Old Apr 8, 2003 | 02:39 PM
Kamin's Avatar
Default Re: how do i get rid of that annoying beeping noise? (fowler)
thats for the seatbelt light, isnt it?
Old Apr 8, 2003 | 02:54 PM
fowler!'s Avatar
I think it disables the beeping too. For some reason, I disconnected it on my old car and never heard that beeping again. The seatbelt light never showed up either...
Old Apr 8, 2003 | 03:35 PM
krazy's Avatar
theres a how to for this posted a few days ago. very easy steps, but i need pics to explain it. search terms like "key remove buzzer" or something like that. i totally forgot.
krazy
Old Apr 8, 2003 | 09:22 PM
ummmm fuse?
Old Apr 8, 2003 | 10:03 PM
tominos's Avatar
on my car if you turn the ignition to the on position instead of the acc position, it stops beeping with the door open after a couple seconds.
Old Apr 9, 2003 | 08:46 AM
Default Re: how do i get rid of that annoying beeping noise? (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos &raquo;</TD></TR><TR><TD CLASS="quote">on my car if you turn the ignition to the on position instead of the acc position, it stops beeping with the door open after a couple seconds.</TD></TR></TABLE>
as with every car....but you are going to kill your battery if you leave it like that.
Old Apr 9, 2003 | 08:47 AM
IS3Fifty's Avatar
Default Re: how do i get rid of that annoying beeping noise? (EG CoUpe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG CoUpe &raquo;</TD></TR><TR><TD CLASS="quote">There is a fuse you can take out...however as annoying as it is right now, you WILL miss it that time you leave your keys in the ignition I did the same thing for a while....hated it.</TD></TR></TABLE>
exactly!
sgull
Oct 2, 2013 07:52 AM
TravisCadello
May 10, 2009 05:34 PM
'96typeR
May 29, 2008 11:12 PM
codyb13
Jan 31, 2005 07:38 PM
spencedogg
Mar 7, 2003 11:33 PM
