Question about turbo
I am looking at various options turbo, supercharge but........ I have an AUTO
eg civic 95 d16z6 is there any point in me putting it in or should i get a b16 swap what kind of HP are we talking if anything in the turbo option?
Thanks
eg civic 95 d16z6 is there any point in me putting it in or should i get a b16 swap what kind of HP are we talking if anything in the turbo option?Thanks
I would do the engine swap then turbo if your still wanting turbo. Always better to turbo the V-tec engines
first off, since your auto, dohc vtec wont be your option since they all come in manual, besides h22 (quote me if i am wrong). unless you do manual conversion but then your looking into some more money.
if your engine is in good compression then i would look into a supercharger instead of a turbo.
1st you will suffer some lag since you are auto, with a supercharger, you will get continuous power throughout your rpm band.
2nd less wear on your engine.
3rd i see them on ebay for about 1000 dollers now a days used. so its a whole lot cheaper then a swap, including a manual conversion.
hope that helps you out.
Z6 is VTEC numb nuts. Don't under estimate the power of the SOHC
How is a super less wear than a turbo?
thats what i have heard about superchargers. i could be wrong. but just from want i know, i am turbo person but i read a lot of good things about chargers, beside the lack of power compared to a turbo.
Actually a turbo on an automatic car does have a slight advantage. First of all you could build boost at a stop with just brake torque. Basically hold the brake down, and give it some gas, your turbo will be at positive pressure even before you take off. On a supercharged application, yes you will have power throughout the powerband, but on takeoffs, your auto tranny will still rob your power buildup till you get going. There is a company in one of the Honda Tuning issues that specializes in revaning torque converters, so you accelerate faster, get better gas milage and can build up your engine more, i forgot the name of the company tho...their work even rivals a manual tranny in some aspects, plus imagine what a sleeper you would be when they see the auto shifter...
robitjcivic
18
May 28, 2008 03:58 PM
