d16y7 bottom end- d16y8 head (mini-me)
Old Apr 7, 2003 | 09:43 PM
whitemike1644's Avatar
Default d16y7 bottom end- d16y8 head (mini-me)
well i have a stock DX motor about 70000 miles on it and i am thinking about upgrading what i got and doing a mini me i found a full EX head for 200 bucks with about 50000 miles complete with manifold and sensor but my question is i heard that it will raise my compression to like a 10.2.1 or something like that.
well i want to go turbo and i am just thinking that if this does up my compression how or what would i need to do to say run a apex turbo kit intercooled with cams valves springs and retainers. and for bottom end rods and pistons.
like would i jsut get lower compression pistons or how would i go about this or would a mini me swap not work good with a turbo set up?
Old Apr 7, 2003 | 09:57 PM
orange.honda's Avatar
Default Re: d16y7 bottom end- d16y8 head (whitemike1644)
well it depends. you can go high comp with turbo and you dont have to boost as much to get the same output as a low comp turbo, but it is a lot harder to pull off.you could just get low comp pistons. or you could leave it high and get a really good fuel management. in the end it all goes down to what you want to run with the car. what times do you want or what are you tring to accomplish. but anyway if you are going to just run a turbo and build the head anyway ( cam, valves, ect.) then you dont need to get a y8 head on it. youll be plenty fast.
Old Apr 7, 2003 | 09:59 PM
Default Re: d16y7 bottom end- d16y8 head (orange.honda)
so your saying don't even get the head and jsut keep the DX one?
your the first to say that what about the intake manifold?
Old Apr 7, 2003 | 10:00 PM
i am hoping like high 13's like even a mid 13 on drag radials nothing spectacular just wanna be able to wax some muscle with a sohc
Old Apr 7, 2003 | 10:05 PM
if you are going to drop in a cam and valves might as well get a p&p. then get the turbo and play with the boost until you get where you want to be. but make sure you manage your fuel responsibly no matter what you end up doin. keep the mani it works way better than yours
[Modified by orange.honda, 7:08 AM 4/8/2003]
Old Apr 7, 2003 | 10:16 PM
well what about tranny options i know the DX kills my accerleration but whick tranny should i get?
and also could i just get pistons rods and rod bolts and be ok with maybe 12 15 psi i know good tunning comes into play but just wanna make sure the **** can handle it
Old Apr 8, 2003 | 10:27 AM
ttt
trav39562
Mar 31, 2009 04:39 PM
memorybox
Aug 14, 2006 08:25 AM
crohnman7
Oct 18, 2005 06:34 PM
whitemike1644
Apr 8, 2003 04:22 PM
whitemike1644
Apr 8, 2003 11:15 AM
