Mini me
Mini me
If i did a mini me swap nad put on the D16z6 head and put in the d16 ecu on my D15 would the compression be to high on the engine to turbo it?
Re: (crohnman7)
how much boost are you planning on? I don't think the compression increase will be big enough to cause you any problems as long as you're not planning on boosting over 7-9psi. And if you were planning on boosting higher than that, you'd want to tear it all apart and beef up the bottom end anyways and install some lower compression pistons.
