ecu pin outs on eg
Old Apr 6, 2003 | 10:43 AM
TORQUE MONSTER's Avatar
Default ecu pin outs on eg
i'm trying to rewire my ecu to put back my d16z motor from a gsr swap.. I forgot wat to do.. basically i just need to undo watever i did to do the b18c1 swap so i can make my stock motor run right
thanks
Old Apr 7, 2003 | 12:01 PM
DerangedEG's Avatar
Default Re: ecu pin outs on eg (TORQUE MONSTER)
Why don't you splice some more wires..!! Doesn't matter which ones just start cutting like you usually do
[Modified by gphybrid, 9:01 PM 4/7/2003]
Old Apr 7, 2003 | 05:47 PM
VTECVillain's Avatar
The only wires added from a D16Z6 to B18C1 would be the knock sensor and intake air bypass if it's wired correctly. There should be no reason why the car wouldn't run properly by swapping the Z6 back in even if you leave that wiring there.
Tippyman
Dec 31, 2005 10:29 AM
Bseriesy0
Sep 21, 2004 10:14 AM
TurboBumblBee
Feb 25, 2002 06:03 PM
greenGSR12
Dec 20, 2001 06:05 PM
