Properly balancing the bottem end
Old Apr 1, 2003 | 01:25 PM
shingles's Avatar
Default Properly balancing the bottem end
While sitting in a meeting, I got to thinking about how to best balance the bottom end. If all the pieces (pistons, rods, crank, flywheel, crank pulley, clutch, pressure plate) are balanced *individually*, could you assume that they would all be balanced as an assembly?
If I am getting my pistons and rods coated, is there enough coating material such that the balance would be off if it was balance prior to coating?
Any comments would be welcomed.
thanks,
-S
GarageAlchemist
Jun 21, 2006 01:30 PM
Propulsion
Nov 26, 2003 06:54 AM
LudeyKrus
Nov 12, 2003 05:37 PM
shingles
Nov 21, 2001 02:46 PM
itr1236
Aug 5, 2001 09:14 PM
