Is this the right way to.... ?
Old Mar 31, 2003 | 10:06 PM
ophdehEEzY
Guest
Posts: n/a
Default Is this the right way to.... ?
Is this the right way to ground the valve cover and head? I bolted one side to the power steering bracket (ground for the head) and one side to the valve cover both meeting at this point. Is is better to ground em together like that or should i run them all to the negative battery terminal? TIA
Old Mar 31, 2003 | 10:09 PM
allmotorEG-SI's Avatar
Default Re: Is this the right way to.... ? (ophdeheezy)
I don't belive they have to go to the battery terminal. As long as they are properly grounded to a metal surface, usually something on the frame, you should be fine.
Old Mar 31, 2003 | 10:40 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: Is this the right way to.... ? (gixxerdemon)
anyone else wanna back that up or debate?
Old Mar 31, 2003 | 11:05 PM
orange.honda's Avatar
ill back him up. as long as the neg betery cable has a clean connection to the frame and the frame to the block then your good.
Old Apr 1, 2003 | 01:00 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: Is this the right way to.... ? (orange.honda)
anyone else?
Old Apr 1, 2003 | 01:10 PM
X0's Avatar
X0
You should be fine...wait, you did prep that spot before you grounded to it though right?
Old Apr 1, 2003 | 01:13 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: Is this the right way to.... ? (BAdMutHA)
yea, i sanded it down a bit.
Old Apr 1, 2003 | 01:30 PM
JimBlake's Avatar
Now that the wire's bolted on tight, put some grease or something over it so it doesn't corrode.
Razr2
Oct 15, 2008 06:31 AM
LDS
Sep 25, 2007 06:02 PM
Racermech
Apr 2, 2005 12:31 PM
puffxy
Aug 9, 2004 07:05 PM
Krnbk2
May 30, 2004 06:11 AM
