how much boost on Z6 + 14b = 200whp?
Old Mar 31, 2003 | 07:06 AM
Crazy Cooter's Avatar
Default how much boost on Z6 + 14b = 200whp?
How much boost would I need to run on a Z6 motor for 200 whp with a 14b turbo? I'm guessing ~12psi (stab in the dark), but how would I go about properly estimating that? Anyone running this set-up with 200whp? I'm just checking to make sure I build it to last.
Old Mar 31, 2003 | 08:15 AM
RGAZ's Avatar
New User
Default Re: how much boost on Z6 + 14b = 200whp? (Crazy Cooter)
Can do it with a well-tuned 11 psi.
Build away!!!
Randy
Old Mar 31, 2003 | 09:29 AM
Charlie Moua's Avatar
yeah that sounds about right
Old Mar 31, 2003 | 09:46 AM
turbod16y8's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (Charlie Moua)
hey how much will u estimate 8psi on d16y8 and 14b. semi tune.
Old Mar 31, 2003 | 10:20 AM
1.8T_EG's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (turbod16y8)
... how about z6 built with turbopanda's rod/piston combo and a t3?... how much boost to equal 200whp?...
Old Mar 31, 2003 | 11:26 AM
Civic_95_Si's Avatar
On alot of the smaller turbos it'll take about the same 10-12 PSI for 200WHP. Once you get into the bigger ones maybe 8-10. I'm hoping to boost 200WHP with an AX53B60-P18 .
[Modified by Civic_95_Si, 8:32 PM 3/31/2003]
Old Mar 31, 2003 | 12:04 PM
Default Re: how much boost on Z6 + 14b = 200whp? (Civic_95_Si)
Thanks guys, I was just wondering if I was in the right ballpark.
Old Mar 31, 2003 | 12:26 PM
94dxt's Avatar
my friend's d16z6 w/a t3/4 and 14 psi (9:1 comp) put down 250 whp and 205wtq and that was when his exh. manifold had a fat crack in it
Old Mar 31, 2003 | 12:45 PM
AbaZ's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (94dxt)
180hp / 184tq
165k mile stock d16z6 with a custom 14b turbosetup I made.. running 10psi on the dyno, tuned with dsm 450's and a fields boxter vtec controller.
If we had something a bit better to tune with, I probably could have made some more power..
Jeff
[Modified by AbaZ, 9:48 PM 3/31/2003]
Old Mar 31, 2003 | 01:04 PM
SiRkid's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (AbaZ)
i call bullshit.
no way you make more torque than hp
Old Mar 31, 2003 | 01:41 PM
AbaZ's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (SiRkid)
i call bullshit.
lol, call what you want.. this has been posted on my site for over 6 months, alot of people dont belive it. The reason it has more torque than hp is due to the custom spring setup we have on the internal wastegate actuator.
And why the **** would I even bullshit something like this anyways? gimme a break.. lol
I have a member on my board boosteded9, who was making a little bit over 300 hp on a stock d16z6 boosting 20psi, with a custom setup.. but finnaly blew the ****** up..
check it out
http://www.homemadeturbo.com/turbo_p...-t4/index.html
the updated dyno isn in their, and the pictures of the blown engine are somewhere on the forum...
Jeff
[Modified by AbaZ, 10:43 PM 3/31/2003]
Old Mar 31, 2003 | 01:46 PM
94dxt's Avatar
those #'s are very possible(more tq than hp) although you should be putting down more than that, are you running rich? bigger inj aren't nesissary for 10psi
[Modified by 94dxt, 2:47 PM 3/31/2003]
Old Mar 31, 2003 | 01:58 PM
AbaZ's Avatar
As I said it has to do with our custom wastegate... and tuning was very limited for what we were using, just a fields controller, and I was playing with a bit of base timing.
stock injectors at 10psi, at probably 180% duty cycle, ya thats real safe..
Trust me, I know how engine management works, since I have done probably over 15 different turbo setups on peoples cars
JEff Frank
[Modified by AbaZ, 11:00 PM 3/31/2003]
Old Mar 31, 2003 | 02:09 PM
BoostedED9's Avatar
i call bullshit.
check it out
Jeff
anything and everything is possible, you just have to try it and find out for yourself like i did.... there is a pic of my dyno sheet in teh link on my sig but i dont think theres pics of the blown motor in tehre..... btw i did 302@16.5psi, it blew when i went over 20
Old Mar 31, 2003 | 02:51 PM
ill_take_one's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (BoostedED9)
what was your setup man? (b00stedED9)??
I'm very curious, becuase i was shooting for 300hp, but i thought i was going to have to boost about 20psi.
I'll be running a T3/T4 50 trim .48 A/R hotside, .56 A/R compressor..
Peace
ps. that avatar turns me on kinda...who is she?
Old Mar 31, 2003 | 06:45 PM
BoostedED9's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (ill_take_one)
Peace
thers a list of my setup on the link to pics of my car in my sig..
that girl is accordgrl she posts on this board frequently..
Old Mar 31, 2003 | 07:56 PM
norcalcrx's Avatar
Its deffinately possible to make more tq then whp. Check out my sig. Do a search on my name and you will see the dyno's.
Old Mar 31, 2003 | 08:42 PM
yellowsub's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (norcalcrx)
I think the, , means he was kidding
Old Mar 31, 2003 | 09:25 PM
GOLDBERG's Avatar
i thought the 302 was made on 16psi, and when he went for 20psi after running thre 11.8 with the 16psi 302, he blew motor???still SUCH awesome #'s...d16 rock on!!!!
Old Apr 1, 2003 | 04:50 AM
BoostedED9's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (GOLDBERG)
yes 16psi was when i made 302, i went over 20psi when the motor blew up at the track.. i ran 11.8@16.5psi...
Old Apr 1, 2003 | 05:42 AM
M.A.R.C.'s Avatar
in respect to the post topic... I made about 194whp @ 8.5-9psi on a T3 60-trim turbo with a flat a/f curve between 11.-12.0 coulda pulled 200 most likely if i leaned it out a lil more. On a 14b, probably a lil more boost to pull 200whp.
Old Apr 1, 2003 | 07:46 AM
SiRkid's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (yellowsub)
LMAO..
I WAS KIDDING..hence the at least someone caught it
Old Apr 1, 2003 | 08:19 AM
Smashback's Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (CivicRyda2k)
We don't want no if's and's or but's...
I made exactly 206hp/184tq at 9 PSI on a D16Y7 w/ Y8 head and T3/4B turbo.
Old Apr 1, 2003 | 04:24 PM
M.A.R.C.'s Avatar
Default Re: how much boost on Z6 + 14b = 200whp? (Hatchblack)
show me up why don't ya... lol... man i need a bigger turbo
Old Apr 1, 2003 | 05:37 PM
shermanyang's Avatar
from the little experience i have with turbos, don't you make more tq than hp if you're running a small turbo? correct me if i'm wrong someone.
2kdrift
Aug 18, 2010 02:12 AM
Ahknodd
Feb 22, 2009 05:57 PM
themorphious
May 30, 2006 02:48 PM
-16V-
Mar 1, 2004 01:35 PM
zseeanz
Nov 16, 2003 07:56 PM
