Should I boost it or not????
Old May 29, 2006 | 06:35 PM
themorphious's Avatar
Default Should I boost it or not????
Ok, as the title says, i'm trying to decide if i should boost my d16z6. It's a pretty much stock z6 with about 140,000 on the motor. I have absolutely EVERYTHING for putting my turbo kit on...but i've run into a problem......i am in college, will be finished soon, as in dec., but am worried about running 5 lbs of boost now till i graduate. I havent put it on......but the itch is getting GREATER, and GREATER every day. BTW, this is my daily driver. I would be able to get the turbo on and tuned with uberdata in the same weekend(hopefully).....do you guys think i'll be safe with 5 lbs, now till december....???? and one more thing.........how long do d's usually last on something like 5 lbs with a good tune? especially one with this kinda mileage....ive seen alot higher milage.......but jsut asking..
Old May 29, 2006 | 08:29 PM
Default Re: Should I boost it or not???? (themorphious)
bump for some suggestions...
Old May 29, 2006 | 08:33 PM
AbitAvenger's Avatar
I've got over 200k on a z6 with 8lbs on a 14b
ARP headstuds are the only addition
If you get a good tune and the motor has good compression then I wouldn't even worry about 8lbs
john d
Guest
Posts: n/a
you coulda saved some time by going ahead and putting the set up on instead of making this post
Old May 29, 2006 | 09:01 PM
Default Re: Should I boost it or not???? (john d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">you coulda saved some time by going ahead and putting the set up on instead of making this post </TD></TR></TABLE>He was asking wether it would be safe for the time being since he mentioned he will be on limited funds because of college.
Old May 29, 2006 | 09:33 PM
civic nation's Avatar
dont be a puss jk slap that turbo on and push 1o maybe even 12 on a good tune on a cold day f school haha
Old May 30, 2006 | 03:39 AM
john d
Guest
Posts: n/a
Default Re: Should I boost it or not???? (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">He was asking wether it would be safe for the time being since he mentioned he will be on limited funds because of college. </TD></TR></TABLE>
thanks for the clearifacation but i can read. sorry that you couldnt find the sarcasm in my post
Modified by john d at 4:41 PM 5/30/2006
Old May 30, 2006 | 06:15 AM
b18sihatch's Avatar
yea just do a leakdown test, compression test and if every looks good go ahead
Old May 30, 2006 | 06:24 AM
nota-eg's Avatar
Default Re: Should I boost it or not???? (b18sihatch)
Only 140k? Are you nuts? That motor is hardly broken in.
230k pushing 15psi semi-tuned for almost a year.
Just make sure you tune it, or you'll have shot rings in your #1 cylinder.
Old May 30, 2006 | 06:41 AM
Default Re: Should I boost it or not???? (nota-eg)
thanks guys for all the help!!! really..i appreciate it...i just get nervous about it.......i have a friend who has had multiple problems with his eclipse pushing 8 lbs...but no fuel setup besides a fmu..and no ignition timing controller......so......i guess it's a go.......tanks for the help guys
Old May 30, 2006 | 07:52 AM
wickedEG's Avatar
</TD></TR></TABLE>Well if it's a case of limited funds then you shouldn't even think about putting a turbo. You might put it on and it could last a long time or the first time you go in to boost you could blow it. You really need to do it right and be ready for the worst.
Old May 30, 2006 | 01:43 PM
skylinetph26's Avatar
Default Re: Should I boost it or not???? (wickedEG)
GOD YES you should put the kit on, just make sure the motor is in good working order before you do so
Old May 30, 2006 | 01:44 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
just boost it, d-series long blocks are dirt cheap
Old May 30, 2006 | 02:48 PM
Pay2play killa's Avatar
Default Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">just boost it, d-series long blocks are dirt cheap</TD></TR></TABLE>
right;
if you blow it spend $50-$100 and get a newer lower millage shortblock
jdmEFmike
Jun 10, 2010 05:57 PM
projectef
15
Jul 9, 2007 04:42 PM
fms1day
20
Jul 6, 2006 12:57 AM
f22suzuka
Aug 3, 2003 06:15 PM
Crazy Cooter
Apr 1, 2003 05:37 PM
