safe boost for d16
Old Nov 11, 2003 | 05:44 PM
zseeanz's Avatar
Default safe boost for d16
I have a d16y8 with stock internals. What's the highest boost I can safely perforn with this daily driver. Right now @ 6psi. I was hoping to get up to 9 or 10 safely w/o hurting my motor
Old Nov 11, 2003 | 05:49 PM
zseeanz's Avatar
Default Re: safe boost for d16 (zseeanz)
anyone?
Old Nov 11, 2003 | 06:10 PM
Drew Peacock's Avatar
Try a freaking search you think your the first one to ask this????????????????
Old Nov 11, 2003 | 06:15 PM
M.A.R.C.'s Avatar
for a detailed answer do a search... to sum it up... you can run a pretty decent boost level as long as it's tuned for. also remember the motor will break because of the HP... not necessarily boost level. so u could do 10psi on a t-25 but 10psi on a 60-1... i wouldn't recommend for stock internals. if you search ull find a lot of d-series people run between 6-12 (on average) psi safely on stock internals once well tuned
Old Nov 11, 2003 | 07:23 PM
Johnyquest's Avatar
Default Re: safe boost for d16 (CivicRyda2k)
10psi on a t3 here, just don't **** w/ ur stock revlimter and you'll be fine...
oh yeah, that's untuned afc hack.
Old Nov 11, 2003 | 08:34 PM
Del_Slowest's Avatar
Default Re: safe boost for d16 (Johnyquest)
Compression is okay, the D16Z6/Y8 can handle a nice amount of boost ( 12 psi ) if you don't go above 6k rpm's. Rev's are not your friend, it's the hight reving of the engine that will kill it when it's turboed. I won't go above 6k on mine at all, and i have a 7200 redline....
Old Nov 16, 2003 | 07:13 PM
OoHiTzToMMy's Avatar
Default Re: safe boost for d16 (Del_Slowest)
IM about to trubo my d16 also..i was wondering why not take it past 6k rmp
Old Nov 16, 2003 | 07:18 PM
M.A.R.C.'s Avatar
Default Re: safe boost for d16 (OoHiTzToMMy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoHiTzToMMy &raquo;</TD></TR><TR><TD CLASS="quote">IM about to trubo my d16 also..i was wondering why not take it past 6k rmp</TD></TR></TABLE>
you can take it past 6000rpm... tons of people do it. but the thing is don't take it PAST your stock REDLINE. also if you're not beating on it from light to light hitting redline every time u do it... it shouldn't be any problem. my redline is 6900... i don't revv it past that.... well i have once or twice but that's another story hehe.
Old Nov 16, 2003 | 07:47 PM
Ricey McRicerton's Avatar
Search for gods sake...or how about just try 20psi..that's what I would run. Anyways, your clutch will give up long before your internals will.
Old Nov 16, 2003 | 07:56 PM
M.A.R.C.'s Avatar
Default Re: safe boost for d16 (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Search for gods sake...or how about just try 20psi..that's what I would run. Anyways, your clutch will give up long before your internals will.</TD></TR></TABLE>
lol
10 psi
Jan 27, 2018 04:58 AM
JDM_Acccord
Jul 5, 2007 03:24 AM
egVTI
May 12, 2006 01:52 AM
1990hondaHF
Aug 21, 2005 01:39 PM
projectTeG
Nov 7, 2003 06:56 PM
