all those w/out BTM
Old Mar 29, 2003 | 08:47 PM
dirtySOHC's's Avatar
Default all those w/out BTM
alot of ppl in here run the AFC hack, i wanted to know wat you guys are doing for timing. Have you left it stock, have you retarded? Being that timing is so critical i am paranoid as hell to run the **** out of my car.
i will be putting my car on the dyno next friday and i wanna tune it to run 8lbs safley all day long. right now i got it retarded about 3 degrees at the dist.
i just hate looking through the board seeing the "blew my motor" threads and reading tham and ppl are like "i dont know how this happened, i had it tuned and everythying"
im so happy to finally be boosted but at the same time scared out my mind.
D16Y8
T3/T4 (Maxrev kit)
DSM 450's
VAFC
walbro 255
[Modified by dirtySOHC's, 5:48 AM 3/30/2003]
Old Mar 29, 2003 | 09:27 PM
extrmeboost's Avatar
Default Re: all those w/out BTM (dirtySOHC's)
im running almost the same setup (custom kit) but fuel system and hack are all the same, i havent touched my timing yet but im interested to see what happens when i do, is it just a safety measure or will it make the car run smoother?
Old Mar 30, 2003 | 04:53 PM
Default Re: all those w/out BTM (extrmeboost)
with my timing retarded at 3 degrees the car pulls really strong all the way through. it pulls better than when i had stock timing. i am also almost 5K ft above sea level so that plays a role on the performance of my car.
Old Mar 30, 2003 | 07:52 PM
Xscream's Avatar
I'm running 13 degree base timing on my LS turbo - awesome and no knock issues... Better to play it safe than sorry
Old Mar 30, 2003 | 07:54 PM
TurboDC4's Avatar
Default Re: all those w/out BTM (Xscream)
Sell the vafc and get an uberchip. This retards the timing for you.
Old Mar 30, 2003 | 09:08 PM
T3's Avatar
T3
Default Re: all those w/out BTM (TurboDC4)
How much?
Old Mar 31, 2003 | 05:28 PM
Infinity_Racer's Avatar
Default Re: all those w/out BTM (T3)
its $100 and another $20 if you want him to chip it for you...search under his name and you'll find all the info on his chips...i'll be ordering mine soon and sending my ecu to him as soon as i can find a car to drive around for a while
Old Mar 31, 2003 | 05:31 PM
Evil EG's Avatar
Default Re: all those w/out BTM (Infinity_Racer)
Just run race gas and you dont need to retard your timming.
Old Apr 1, 2003 | 07:04 AM
i would but doesnt he only chip OBD-1 non vtec ecu's?
that would mean i have to get the chip, another ecu, and a conversion harness. that cash just aint on me right now
Old Apr 1, 2003 | 07:30 AM
b16ahybrid's Avatar
nope i've been informed by him that he now supports vtec .......
Old Apr 1, 2003 | 02:37 PM
T3's Avatar
T3
Default Re: all those w/out BTM (b16ahybrid)
€ØØl.....I might look into it...Thanks
Old Apr 1, 2003 | 06:21 PM
shermanyang's Avatar
UberTeg's Chips gets my vote!! you can run a 3bar map and use your afc to tune. i'm only a few days away from using my UberChip...due the fact that my motor has only 123 miles on my newly built motor. his chip...is truly...a poor man's hondata!!
[Modified by shermanyang, 3:22 AM 4/2/2003]
Old Apr 1, 2003 | 06:24 PM
UberTeg's Avatar
Default Re: all those w/out BTM (shermanyang)
-werd- I do highly recommend th use of an afc for tuning tho
Old Apr 2, 2003 | 12:57 PM
Nissmaxx's Avatar
Default Re: all those w/out BTM (UberTeg)
General rule of thumb is this for every 1 pound of boost you have to retard the timing .2 of a degree this less then half a degree per pound. For example for 8 pounds of boost you would need to retard timing to 2 full degrees. 3 degrees is overkill but safe until you check everything on the dyno. Only use 91 + octane. or better on a race day you could probably go higher on the timing but I would not unless you have an avcr hack or hondata, fuel controller with lower compression. Hope this helps...
Old Apr 2, 2003 | 02:53 PM
Default Re: all those w/out BTM (Nissmaxx)
cool.......ill be on the dyno next tuesday
Old Apr 2, 2003 | 08:33 PM
Pengo's Avatar
yea i think 2 degress retarded would be fine for u. 3 is def safe but i dont think its necessary. best to tune it on dyno anyway tho, so we'll see what happens when u get it done. good luck and have fun
Old Apr 2, 2003 | 08:38 PM
UberTeg's Avatar
Default Re: all those w/out BTM (Pengo)
u guys arent taking into accoutn the fact that the afc hack advances timing. If you want to correct it on your dizzy, u'll have to retard at LEAST 6 degrees.
Old Apr 2, 2003 | 09:34 PM
Joseph Davis's Avatar
You can't correct AFC timing with a BTM. You have to alter the ignition map in your ECU in order to have the correct timing. Or run a Uberchip. Whatever.
othick
Oct 27, 2003 12:39 PM
asianspeed
Aug 8, 2003 05:05 AM
GraphiteAccord
Jul 12, 2003 11:31 AM
spike
Nov 21, 2002 08:30 AM
legendboy
Sep 27, 2002 09:26 AM
