4kthose with a TURBO XS boost contoller.....
i hooked mine up and it seems like it takes alot longer to boost. does anyone have that problem?
i use to start boosting around 4k...now with the boost controller its around 5.5k. did you have to adjust anything?
my set up
b18b
drag 3
garrett t3/to4e
my set up
b18b
drag 3
garrett t3/to4e
how long is the line? If the line is longer, it will create boost lag rather than help "decrease" it. I hope you didn't route the MBC into the cabin of your car
-ryan
-ryan
How is it hooked up? and of course you have to adjust it, they are not set for any specific aplication , you normally have to turn the allen screw out till you , get to the bleed threshold, then, when you turn it out any more it will raise boost, just being oinline with the turbo and wastegate will raise boost the slightest bit with a manual controller. Make sure it is hooked up, and adjust it , should boost earlier. Jason
the hosting site i go to is down. i will post a pic asap. basically i hooked up my wastegate to the brake booster. i cut the line in half and thats where i connected the boost controller. its right above the valve cover.
try going through your lines and look for any leaks or cracked hoses, make sure you had the initial setup correct (liek someone said earlier), etc.
thanks,
Ryan
hope that helps......yea ill check for leaks. i heard air coming out of the boost controller. its suppose to be like that right? since its a bleed type BC. can anyone verify this?
i think the top part of the wg is for electronic boost controllers. this one is manual....thats why i hooked it up like that.
SloB16crxMike
Aug 15, 2006 10:31 AM
