how to do a leak down test
Old Mar 28, 2003 | 03:59 PM
Dorikamu's Avatar
Default how to do a leak down test
arch. search doesn't work
Old Mar 28, 2003 | 04:58 PM
boostaholic's Avatar
Default Re: how to do a leak down test (chusai)
You'll need a leakdown tester and an air compressor. Set the piston to TDC, pressurize the cylinder to 100psi and the gauge will tell you how much cylinder leakage you have.
Old Mar 28, 2003 | 04:59 PM
psi420's Avatar
Default Re: how to do a leak down test (boostaholic)
Old Mar 28, 2003 | 07:09 PM
SJP0tato's Avatar
Default Re: how to do a leak down test (psi420)
Something I've never understood though: how long do you leave it for? I mean, let's say arbitrarily the #3 cyl is leaking a bit through the intake valves. If it was left for 2 seconds then measured, wouldn't it be a different reading than if it were left for 20 seconds? Or is my thinking of how a leak down test works off somehow?
Always wondered,
Ryan P.
ParadoxTeg
May 5, 2015 04:55 PM
Skunk.Werks
Feb 14, 2013 04:48 PM
flipldls
Nov 28, 2010 04:41 PM
B2FiNiTY
Jul 21, 2003 01:02 PM
lazy bum shaughn
Jan 28, 2003 07:55 PM
