Running rich!!!!!! CEL #5 (map sensor)
Old Mar 21, 2003 | 02:48 PM
HaUTSaauce's Avatar
New User
Default Running rich!!!!!! CEL #5 (map sensor)
car is running really rich sometimes bogs while i accelerate and gets bad gas mileage. Checked the CEL and got #5 changed the map sensor 3 times and still get the same code and run way too rich. What are some things i can check to get rid of this problem.
mods: 2.25 full exhaust, GSR block, type-r pistons, b16 head, gsr cams, 1st gen throttle body, stock headers. p72 ecu
[Modified by HaUTSaauce, 5:16 PM 3/21/2003]
Old Mar 21, 2003 | 03:16 PM
HaUTSaauce's Avatar
New User
Default Re: Running rich!!!!!! CEL #5 (nscivic)
b16 head gsr block my bad
Old Mar 22, 2003 | 09:07 AM
HaUTSaauce's Avatar
New User
Default Re: Running rich!!!!!! CEL #5 (HaUTSaauce)
anyone?
Old Mar 22, 2003 | 09:51 AM
Chiovnidca's Avatar
Did you check the vacumn line to the map sensor for leaks?
Old Mar 22, 2003 | 12:38 PM
HaUTSaauce's Avatar
New User
Default Re: Running rich!!!!!! CEL #5 (TurboD16Chiovnidca)
yes i did check that
Old Mar 22, 2003 | 01:28 PM
Chiovnidca's Avatar
Did you check the wiring and connectors going back to the ECU?
Old Mar 22, 2003 | 04:49 PM
HaUTSaauce's Avatar
New User
i will give that a try
Old Mar 23, 2003 | 05:56 AM
HaUTSaauce's Avatar
New User
still didnt fix it
any more ideas?
Old Mar 25, 2003 | 03:34 PM
muska411's Avatar
check your injectors i had a injector that was stuck open and mine did the same thing it would bog and i got real shitty gas mileage. Does it only bog when its cold or all the time?
Old Mar 25, 2003 | 03:40 PM
Chiovnidca's Avatar
any more ideas?
Is you cam timeing right?
D-seriousBis
Apr 11, 2013 05:07 PM
msinsky14
Nov 25, 2008 05:57 PM
hkboy87
Dec 25, 2007 01:20 PM
5_Lug_B
Jul 17, 2007 04:32 PM
93c1sol
Sep 8, 2005 11:06 AM
