switching manifolds - broken stud in the head
Old Mar 21, 2003 | 01:15 PM
pub's Avatar
pub
Default switching manifolds - broken stud in the head
I broke my far left bottom manifold stud when putting my header back on.
I guess I torqued it a bit too much (gotta stop lifting them weights). Is there a better way of getting that stud out and replacing it? While we're on the topic - what is the thread/pitch of the stud? Thanks - I appreciate it.
Old Mar 21, 2003 | 01:19 PM
boostin b16's Avatar
Default Re: switching manifolds - broken stud in the head (pub)
just get an "easy-out" kit. drill a small hole in the broken stud and use the provided tool to get it put!
Old Mar 21, 2003 | 01:37 PM
pub's Avatar
pub
Default Re: switching manifolds - broken stud in the head (boostin b16)
Interesting: can you provide more info about this?
Old Mar 21, 2003 | 01:43 PM
bottlefedb18c1's Avatar
but dont break the easy out in there unless you want to bring the head to me and have it burt out with a EDM (Electronic Discharge Machine)
Old Mar 21, 2003 | 02:08 PM
Tinker219's Avatar
I have broken off EVERY SINGLE stud in that location, on any honda motor. must be a hot-spot in the honda heads...hmm.
Old Mar 21, 2003 | 02:13 PM
Smashback's Avatar
I assume they're talking about a bolt extractor. You drill a hole in the middle of the stud, then use the extractor, which is like a dull drill bit that will turn counterclockwise. It will drill in a little inside the hole and then "bite". After that, the drill will unscrew the stud. Does that make sense?
I had to replace two of my intake studs last week...don't ask.
Old Mar 21, 2003 | 02:51 PM
Sonny's Avatar
Default Re: switching manifolds - broken stud in the head (Hatchblack)
What happened?
Sonny
pub's Avatar
pub
I dont know about how much slack I have, but what about welding the piece on and then trying to unscrew it? Tinker- what did you do to fix your studs? -- or did you?
ToTriggerHappy
Feb 19, 2010 06:33 AM
Liquidgsr
Mar 7, 2005 09:17 AM
Jdmglenn
Jan 31, 2005 09:50 AM
Flamenco-T
May 21, 2002 05:36 AM
Trevor Brown
Sep 2, 2001 08:42 PM
