Help problems after JRSC install.
Old Mar 20, 2003 | 02:00 PM
Bewkrazed's Avatar
Default Help problems after JRSC install.
i got a 98 gsr and i just put the SC in now my idle is really low like around 400-500 and the car shakes alot. plus wen i brake really hard my car just dies out, it literally just turns off. anybody knows wats worng and how do i fix this??
thanks.
*oh great the CEL turned on and it says i am running too rich*
Old Mar 20, 2003 | 02:29 PM
greekspeed's Avatar
Default Re: Help problems after JRSC install. (Bewkrazed)
Try these things:
1. Ur jackson FMU might be pumping too much fuel into your engine (depending on if u have other fuel mods such as big injector and/or fuel pump..), so mess with it a little bit so that the fmu isnt flowing at its maximum capacity..that might help
2. There is an adjustment u can make on the throttle body that makes u idle less and more....... i had a similar problem when i installed my jrsc and this fixed.....when i was messing with it i was making my car idle from 500-1100 depending on where i adjusted it....... i havnt messed with it fr a long *** time though so i'll pop my hood and to find what exactly i was messing with on the thrittle body and get back to u...
Old Mar 20, 2003 | 02:30 PM
maxpsi's Avatar
Did you hook the IACV back up?
If your CEL is right, then the problem could be dumping crap loads of fuel into the engine.
Old Mar 20, 2003 | 02:37 PM
Sonny's Avatar
Do you have any gauges? (Please say yes )
Sonny
Old Mar 23, 2003 | 12:46 AM
Bewkrazed's Avatar
Default Re: Help problems after JRSC install. (Sonny)
hehe sorry no guages trying to keep this as sleeper as possible
i tried the idle screw nothing was fixed now i gotta look into the FMU thingy... so you guys think it is too much fuel in the system that is causing all this problem.
yea im pretty sure i hooked the IACV back up.
wat else could be the problem???
Desperado
Feb 2, 2004 04:45 PM
94jaxgsr
Jul 20, 2003 08:16 PM
DeDonDeRosa
Dec 22, 2002 06:13 AM
keebler65
Nov 4, 2002 03:47 PM
