Bogging at idle after JRSC install!?
Old Feb 2, 2004 | 02:37 PM
Desperado's Avatar
Default Bogging at idle after JRSC install!?
After putting on a JRSC my car seems to bog and shake very violently. The exhast is shooting out black smoke. Also I keep on hearing a loud ticking sound coming from inside the car when it is first started up. Can anyone help me an d let me know what the problem could be?
Old Feb 2, 2004 | 02:40 PM
twkdCD595's Avatar
Default Re: Bogging at idle after JRSC install!? (Desperado)
what kind of fuel management you using?
sounds super rich.
Old Feb 2, 2004 | 02:49 PM
psi420's Avatar
What is your base timing set at?
Old Feb 2, 2004 | 02:53 PM
BEASTLY's Avatar
if ur fuel is set up right then the chargers bad, did u buy it new or used, make sure the belt driving the charger aint too tight itll **** it up
Old Feb 2, 2004 | 04:43 PM
keebler65's Avatar
Default Re: (BEASTLY)
what rpm does it idle at? if its idling really low that could be the cause of the shaking. if so, turn the idle adjustment screw on the throttlebody.
Old Feb 2, 2004 | 04:45 PM
FULLTHROTTLE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEASTLY &raquo;</TD></TR><TR><TD CLASS="quote">if ur fuel is set up right then the chargers bad, did u buy it new or used, make sure the belt driving the charger aint too tight itll **** it up</TD></TR></TABLE>
WTF?
integuy98
May 30, 2006 08:34 AM
98civic94gsr
Apr 13, 2006 09:34 AM
Weapon_R
Nov 4, 2004 05:29 PM
Weapon_R
Sep 12, 2004 02:37 PM
Bewkrazed
Mar 23, 2003 12:46 AM
