y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak????
Old Mar 20, 2003 | 10:00 AM
lsvtec101's Avatar
Default y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak????
just started her up for the first time and pulled the plugs they were filled with oil and antifreeze.... do i need a special headgasket for this setup or was the headgasket not sealed right???
Old Mar 20, 2003 | 10:12 AM
SPOON_BeIgHtEeNsEe's Avatar
Default Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (aemcivic_02917)
did u put on the gasket the right way??? did u also trouqe the head bolts?
[Modified by SPOON_BeIgHtEeNsEe, 7:14 PM 3/20/2003]
Old Mar 20, 2003 | 10:29 AM
Smashback's Avatar
sounds like you forgot to put the gasket in all together...or maybe you left a wrench on top of the block when you isntalled the head
J/K that's not normal, obviously. I never had any problems with mine. Did you use a NEW gasket?
lsvtec101's Avatar
Default Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (SPOON_BeIgHtEeNsEe)
yes im 99% i put the headgasket on correctly, and i torque the head twice in the right seq. order. im guessing i need a headgasket made or was this a result of poor install?
Old Mar 20, 2003 | 10:32 AM
lsvtec101's Avatar
brand new y8 headgasket from honda i re used the head bolts too b/c the arp bolts didnt fit
Old Mar 20, 2003 | 10:35 AM
Smashback's Avatar
Just replace it again, something went wrong unless there is something wrong with the head or block.
Everybody whines about not re-using head bolts but there's no problem doing so. 90% of engine builders don't replace head bolts just for the heck of it.
Old Mar 20, 2003 | 10:40 AM
lsvtec101's Avatar
Default Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (Hatchblack)
so u guys with y7 bottom ends and y8 heads do you use a Y7 or Y8 headgasket .. let me know peeps i need to know asap.....
btw i had the head resurfaced would that raise the compression? also it didnt leak around the outside of the block so is there anyway when i take the head off would i be able to tell where it was leaking from?
[Modified by aemcivic_02917, 11:40 AM 3/20/2003]
Old Mar 20, 2003 | 10:44 AM
Smashback's Avatar
If your deck/sleeves are out of what this could happen but I doubt that's it. If I remember right, the Y7 and Y8 gaskets are the same. I think I used a Y8, but I do think they are the same. Look up the part numbers at autozone and check them.
Old Mar 20, 2003 | 10:51 AM
lsvtec101's Avatar
would resurfacing my head raise the compression?
Old Mar 20, 2003 | 08:14 PM
SDT Project EF's Avatar
i think yoru supposed to take out one of the oil restrictors on the block
Old Mar 21, 2003 | 02:36 AM
lsvtec101's Avatar
Default Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (SDT Project EF)
hmnmmmm
Old Mar 21, 2003 | 04:47 AM
JRSCCivic98's Avatar
Yes it would... it would also possibly explain the leak if it was done wrong. If the head is not TRUE, then it'll definatly leak. By TRUE I mean perfectly flat. If it's not TRUE, then it's like getting a leak when you warp the head.
Hope this helps.
BTW, I've seen this before when resurfacing was done crappy.
Actaully, if you just resurfaced and didn't take out any serious amount of metal in the process, then it wouldn't raise the comp. Just wanted to put that in for those falmers out there...
[Modified by JRSCCivic98, 1:49 PM 3/21/2003]
Old Mar 21, 2003 | 05:00 AM
lsvtec101's Avatar
Default Re: y7 bottom end .... y8 head w/ y8 headgasket = headgasket leak???? (JRSCCivic98)
the head was resurfaced by a machine shop. i hope i can find out what caused it when i take the head off or where it was leaking from i doubt it was from the head being resurfaced, i just wanna know what caused it to leak inside of the head and not around the outside of the block
Old Mar 21, 2003 | 05:42 AM
swrdply400mrelay's Avatar
If you re-install another headgasket, why don't you try some copper spray on the new gasket.
Old Mar 21, 2003 | 06:04 AM
Smashback's Avatar
Nope, you've been reading too much about the older SOHC motors. D16Y8 head bolts straight onto a D16Y7 block with no modifications other than wiring.
RedRevolver
Feb 3, 2009 08:42 AM
mjsotelo91
Jun 16, 2008 01:31 PM
justinCO
Jun 10, 2008 09:16 AM
CR-V-tech
Apr 15, 2006 03:15 PM
gabspeed
20
Mar 14, 2005 11:43 AM
