SOHC dyno #'s part 2
Well i got my Hondata s200 (thanks to Kyle from K-S Motorsports) and some Rc 440's and went to the dyno this weekend. Well after a lot of problems (most fixed, but some still there) this is what we came up with.
The biggest problem i am having now is that it still wont hold 10 psi. It spikes to 11 psi and then drops to 9.5 psi. I am going to try and run a seperate line dedicated to the boost controller and hope that this will solve the problem. I was using my greddy profec A and then went to a turbo Xs and it still was doin it but not as bad. Btw these last few runs were pretty heat soaked as the car had been running for a few hours by this time. It pulls like mad now though.
EDIT
Ignore the 5psi as it was at 10psi on both runs .
[Modified by norcalcrx, 5:36 AM 3/20/2003]
[Modified by norcalcrx, 5:59 AM 3/20/2003]
EDIT
This is a D16z6 in a 94 Dx hatch
Greddy turbo kit
Greddy front mount
Hks SSBOV
Greddy Profec A
Greddy Turbo Timer
Hondata s200
Rc 440's
SARD adjustable fuel regulator
AEM Fuel Rail w/pressure gauge
MSD 6al
MSD Blaster Coil
Act 6 puck w/ extreme Pressure plate
Skunk2 exhaust w/ test pipe
I think i got everything.
Edit:
Added skunk2
[Modified by norcalcrx, 2:50 PM 3/20/2003]
Greddy turbo kit
Greddy front mount
Hks SSBOV
Greddy Profec A
Greddy Turbo Timer
Hondata s200
Rc 440's
MSD 6al
MSD Blaster Coil
Edit:
Added skunk2
Argh OK good numbers man good luck, I don't reccomend you run that boost level every day if you have a stock engine about 8psi is all you will want to run, if you want it to last awhile.
good numbers
which skunk2 is that? i'm interested in diameter of piping and muffler.
good job, i wanna get my sohc dyno'd soon since they changed the last date on me
There was a need for the regulator with the blue box but i really dont need it with the hondata now. We have it set for 50 psi right now and its running great.
and i'm looking to buy an EBC.
