How-To: Peg a Dynapack Dyno
Old Nov 8, 2005 | 03:59 PM
Full-Race Geoff's Avatar
Default How-To: Peg a Dynapack Dyno
Step 1: Put car on Dyno
Step 2: Turn Boost Up
Step 3: Make too much power
We were recently testing our heavily modified GT40R turbochargers on my car this past weekend at LocashRacing's Dynapack. Unfortunately we werent able to get any good data. Watch the vdieo for info why. (jeff evans is the commentary ARGHH)
<RIGHT CLICK SAVE AS>
http://www.full-race.com/perso...o.wmv
Old Nov 8, 2005 | 04:04 PM
TurboTagTeam's Avatar
Default Re: How-To: Peg a Dynapack Dyno (Full-Race Geoff)
WOW? That would make a good avator. Did you run it on another dyno?
Old Nov 8, 2005 | 04:05 PM
97turbols's Avatar
that's crazy!! What are the limits on a dynapack? I never though there was such a thing as too much power, oh well.
areyouasian's Avatar
crazy stuff...
Old Nov 8, 2005 | 04:07 PM
Default Re: How-To: Peg a Dynapack Dyno (TurboTagTeam)
ill get it on a dynojet soon, they can measure up to 1200whp. We are deep into the 800whp level right now
just a couple minor setup changes with the new turbo and we get 600whp at 20 psi instead of 26 psi, and 700 whp at 30 psi instead of 39 psi. Very little lag, and huge powerband. We've figured out how to make these GT40Rs work
Old Nov 8, 2005 | 04:10 PM
rhd's Avatar
rhd
um...yeah...done that plenty of time
Old Nov 8, 2005 | 04:13 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">just a couple minor setup changes with the new turbo and we get 600whp at 20 psi instead of 26 psi, and 700 whp at 30 psi instead of 39 psi. Very little lag, and huge powerband. We've figured out how to make these GT40Rs work </TD></TR></TABLE>
The hell did you guys do? Add another B18c motor in there, or what?!
Fawking awesome! The red screen of death! LOL!
yee SERIOUS's Avatar
that's tight. hahaha. i like the snail fan
Old Nov 8, 2005 | 04:16 PM
Andrea's Avatar
My favorite part was watching Joe freak out every time his dyno computer screen went red!
Old Nov 8, 2005 | 04:19 PM
93turbo16's Avatar
that is pretty funny. Hope I get to see that some day.
Old Nov 8, 2005 | 04:22 PM
flip1199's Avatar
Default Re: How-To: Peg a Dynapack Dyno (Andrea)
any hint of what u did to the gt40r?
Old Nov 8, 2005 | 04:33 PM
simike's Avatar
Default Re: How-To: Peg a Dynapack Dyno (flip1199)
Congrats on the 800+ whp!!!! Jeff time to get a second dyno????
Old Nov 8, 2005 | 04:38 PM
alpha's Avatar
ahaha! Good stuff Geoff.
Old Nov 8, 2005 | 04:48 PM
WHTZ's Avatar
Default Re: How-To: Peg a Dynapack Dyno (0x64)
Old Nov 8, 2005 | 05:19 PM
xyrth's Avatar
Default Re: How-To: Peg a Dynapack Dyno (WHTZ)
yah, i love the idea behind the dynos but the 900ft-lbs seems so limiting with today's power level
we pegged a dynojet with a 9L Viper motor we built a while back, at least you can keep pulling and tune the car
Old Nov 8, 2005 | 05:28 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">any hint of what u did to the gt40r?</TD></TR></TABLE>
My guess is nitrous, injected directly into the compressor housing. LOL!
Old Nov 8, 2005 | 06:24 PM
JDogg's Avatar
Default Re: How-To: Peg a Dynapack Dyno (Finest)
did you try running it in a higher gear? dynapack is limited by hub tq, if you max it out... just run it in the next higher gear.
the dynapack 3000 will read up to 2400ft/lbs.. if i remember right its around 800ish ft/lbs at the engine with an LS tranny, about 100 less with a b16 tranny
Old Nov 8, 2005 | 06:35 PM
tony1's Avatar
Default Re: How-To: Peg a Dynapack Dyno (JDogg)
They're also speed limited, right? Can you do a 10k pull in 5th? I'm just asking cause i've never used one, just heard that that's their downfall, being torque and speed limited. What is the speed limit on that model?
Old Nov 8, 2005 | 06:42 PM
JDogg's Avatar
Default Re: How-To: Peg a Dynapack Dyno (tony1)
i have gone 9500 rpms in 5th on a b16 tranny.. the hub is limited to 2450rpm... so you gota do some calculating to get mph from that.
locash's Avatar
Actually, the Dynapack 3000 I have will currently handle up to 3500 nm (2581 ft lbs) of torque at the hubs, its that short b16 4th gear that did it.. For some reason, the car shook violently when we tried to use the LS 5th gear, so I'm working with Dynapack to possible raise that limit to 4000 nm (2950 ft lbs) (or 604 ft lbs at his crank) to remedy this situation, as it sure sucks..
The reason his car makes so much power is because it has a hawaiian mechanic.
Old Nov 8, 2005 | 07:09 PM
seen4ever's Avatar
Default Re: How-To: Peg a Dynapack Dyno (locash)
damn you for making me want to change turbos. I see your ERL block, and then i think ****, my ERL block is done and ready.... damn you for tempting me.
Old Nov 8, 2005 | 07:20 PM
.dave's Avatar
i HAS questions ?
Default Re: How-To: Peg a Dynapack Dyno (seen4ever)
Why is there no windshield on the car?
Old Nov 8, 2005 | 07:26 PM
JDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">Actually, the Dynapack 3000 I have will currently handle up to 3500 nm (2581 ft lbs) of torque at the hubs, its that short b16 4th gear that did it.. For some reason, the car shook violently when we tried to use the LS 5th gear, so I'm working with Dynapack to possible raise that limit to 4000 nm (2950 ft lbs) (or 604 ft lbs at his crank) to remedy this situation, as it sure sucks..
did you have it upgraded?
Old Nov 8, 2005 | 07:27 PM
AlpHaRitEr's Avatar
wow.......
Old Nov 8, 2005 | 07:37 PM
vaporboy12's Avatar
Default Re: How-To: Peg a Dynapack Dyno (AlpHaRitEr)
ive overheated one before. it was the smaller dynopak. im not a baller status liek full-race
