B18c1 crank in b20???
Old Mar 19, 2003 | 07:04 AM
1hottEG6's Avatar
Default B18c1 crank in b20???
I just bought a bare b20 block, having trouble find a stock b20 crank, Can i use a b18c1 or not? (only reason i ask, gs-r cranks seems to be more avaiable..The block is sleeved and im looking to go all motor with jun type III's 12;1. Can b18c1 crank hold well at 84.5 mm sleeves? TIA
Old Mar 19, 2003 | 12:12 PM
1hottEG6's Avatar
Default Re: B18c1 crank in b20??? (1hottEG6)
anyone?
Old Mar 19, 2003 | 12:39 PM
flip b18b's Avatar
umm correct me if i'm wrong but wouldn't putting a b18c brank i a b20 defeat the purpose of haveing the b20?
Old Mar 19, 2003 | 12:55 PM
BabyDaddy's Avatar
Default Re: B18c1 crank in b20??? (flip b18b)
your gonna have to use the entire b18c rotating assembly. the crank has different sized jounals so rods from other b series will not work.
Old Mar 19, 2003 | 06:07 PM
1hottEG6's Avatar
Default Re: B18c1 crank in b20??? (BabyDaddy)
ya gotta learn some how...thanks guys
Old Mar 19, 2003 | 06:18 PM
TimoneX's Avatar
New User
It'll shorten the stroke 1.8mm(-40cc), lower piston speeds, raise the r/s ratio to 1.58:1, and allow the use of stronger GSR & ITR OEM rods.
Old Mar 19, 2003 | 10:13 PM
earl's Avatar
Default Re: B18c1 crank in b20??? (TimoneX)
Why not use an ls crank from b18a/b? I know the rod and main journals are the same size as a b20. Anyone know for sure
Old Mar 19, 2003 | 10:24 PM
TimoneX's Avatar
New User
Default Re: B18c1 crank in b20??? (earl)
The B20b/z crank is the same as the b18a/b crank.
Old Mar 20, 2003 | 08:39 PM
StorminMatt's Avatar
The B18C crank will slightly destroke the B20 (89mm to 87.2mm), reducing displacement from 1972cc to 1927cc. But you will still have a higher displacement than an LS. And with the rod ratio improved from 1.54 to 1.58, it will be more relibale and rev-worthy. Also, as the other guy said, you can use the stronger B18C rods. As for the strength, the B18C crank is at least as strong as the B18A/B18B/B20 crank, if not stronger.
[Modified by StorminMatt, 5:40 AM 3/21/2003]
dannyneedshelp
Oct 15, 2008 09:22 PM
dannyneedshelp
Oct 15, 2008 04:22 PM
5w20
Dec 4, 2004 11:57 PM
COUPE-B20
Oct 16, 2004 02:51 PM
XSBoost
Jun 12, 2001 10:46 AM
