which proportioning valve for civic eg?
Which proportioning valve should I use with a civic dx with front and rear gsr brakes, I was thinking oif using a stock civic hatchback si/ex non abs one? is there any others I can get in the $100 range or is this one good enough?
You can use the one from a 92-95 Si hatchback or one from a 92-93 GSR Integra GSR because they both have all wheel disc brakes...and make sure it has the "4040" number stamped on it..
ya I no to make sure it says 40/40 on it, I just want to no which one will work best with out having to make and bend new lines.
you can use 92-95 civic 30/30 or 30/40 prop valve...you can also use 94-01 40/40 prop valve from a nonabs model...the key is in the bleeding...good luck
I have a 4040 too, BTW. $40 shipped.
00 Coupe EJ8
Mid-Atlantic (Sales)
17
Feb 18, 2010 07:05 PM
