..... sohc TDC .....
Old Mar 18, 2003 | 10:38 AM
lsvtec101's Avatar
Default ..... sohc TDC .....
I have my crank & camshaft TDC. my spark plug wires are in 1-3-4-2. the distrib is off. now when i put my distrib on it is not lining up with no. 1 spark plug..... any suggestions...
Old Mar 18, 2003 | 11:28 AM
kyle h.'s Avatar
Default Re: ..... sohc TDC ..... (aemcivic_02917)
suggestion: your timing is wrong. double check. do you have a manual?
Old Mar 18, 2003 | 02:55 PM
19924ws's Avatar
Default Re: ..... sohc TDC ..... (kyle h.)
Which dist are you using? Use the one that matches the engine. Make sure you're using the right marks to align TDC. Mike
Old Mar 18, 2003 | 03:26 PM
lsvtec101's Avatar
Default Re: ..... sohc TDC ..... (19924ws)
the crank and cam are TDC. the distrib is off timing i know that but how do ifix it..
Old Mar 18, 2003 | 03:55 PM
19924ws's Avatar
Right got that. Are you using the b18 dist or the Dx dist? If you have the wrong one it might not line up. Make sure the rotor inside the dist is lined up with post for #1 cylinder. You could just have that off. Mike
Old Mar 18, 2003 | 04:01 PM
lsvtec101's Avatar
this is on my 7y/y8 setup its all d series parts its the same distrib that cam with the y8 head....
Old Mar 18, 2003 | 04:02 PM
lsvtec101's Avatar
if i adjust the rotor i have to adjust the cam so its either the cam is TDC or the distrib is firing on no. 1 i wish i could get both to line up
Old Mar 18, 2003 | 04:05 PM
Turbo Powa's Avatar
Unbolt the three bolts on the distributor and adjust the dizzy by moving it back or foward untill your within specs.
Old Mar 18, 2003 | 04:06 PM
Turbo Powa's Avatar
Default Re: ..... sohc TDC ..... (Panda EK)
I have no idea what your trying to say now.......
Old Mar 18, 2003 | 04:12 PM
Eee Pee's Avatar
The rotor will be about 16 degrees off.
Old Mar 20, 2003 | 06:40 AM
lsvtec101's Avatar
Default Re: ..... sohc TDC ..... (Eee Pee)
shes on no. 3 when its suppose to be firing on no.1
Old Mar 20, 2003 | 07:02 AM
tilt's Avatar
Just wondering... is the distributor supposed to line up according to TDC or BTDC (the single mark or the 3 line marks on the crankshaft pulley)?
Old Mar 20, 2003 | 07:15 AM
lsvtec101's Avatar
Default Re: ..... sohc TDC ..... (tilt)
my crank is lined up with the the line on the crank gear and the arrow on the block, my camshaft is UP TDC. and its putting my dizzy off
Old Mar 20, 2003 | 07:40 AM
lsvtec101's Avatar
i want to boost already..
Freemananana
Sep 17, 2015 03:43 PM
AlanHall
24
Jul 19, 2011 10:48 AM
ohsnapzafingcu
Sep 7, 2006 01:03 PM
SL_RICK83
Jun 27, 2006 07:38 PM
senpai
Aug 20, 2003 07:08 PM
