jrsc integra ls hp#
Old Mar 10, 2003 | 12:38 PM
redteg's Avatar
Default jrsc integra ls hp#
Old Mar 10, 2003 | 12:41 PM
T-sohctec's Avatar
Default Re: jrsc integra ls hp# (redteg)
non-existant
Old Mar 10, 2003 | 01:45 PM
mskibbz-T's Avatar
Default Re: jrsc integra ls hp# (T-sohctec)
low #s... If you do go that route modify an M62 blower (Type R JRSC) to fit on your LS, the M45 that comes standard on the LS kit is puny.. Either way don't expect huge gains, you would be better of turboing it but you probably know that
Old Mar 10, 2003 | 02:45 PM
redteg's Avatar
Default Re: jrsc integra ls hp# (mskibbz-T)
if i can hit 200 or more i will be happy
Old Mar 10, 2003 | 08:16 PM
T-sohctec's Avatar
good luck!
Old Mar 10, 2003 | 08:40 PM
GSR901's Avatar
the JRSC for the LS is pretty weak. i would go with a turbo or some funny gas with the b18b.
Old Mar 10, 2003 | 09:44 PM
Mr.DC2TurBo's Avatar
Default Re: jrsc integra ls hp# (B18Cwon)
160whp with bolt on and that's stick.. Go with turbo, even tho i'm automatic I'm able to to make 191whp at 8psi
Old Mar 11, 2003 | 08:30 AM
Anyotherone's Avatar
Default Re: jrsc integra ls hp# (LS-T2001)
I'd say on an LS the best way to go is turbo.
Old Mar 11, 2003 | 06:52 PM
redteg's Avatar
Default Re: jrsc integra ls hp# (C_tech97GSR)
thanks but idon't want to go turbo. i don't want thehasselplus i want something different i like throttle response aslo !!!!! so 200 is out of thequestion what about torque
Old Mar 11, 2003 | 06:55 PM
romeo619romeo's Avatar
how about try driving with your AC on all day...and plus when you have your AC on with the SC!!!!!! its HORRIBLE!!!!!!!
Old Mar 11, 2003 | 06:58 PM
redteg's Avatar
Default Re: jrsc integra ls hp# (romeo619romeo)
so what effects does the ac have on the supercharger
Old Mar 11, 2003 | 07:16 PM
illi Adik's Avatar
Its even more accessory drag.
Old Mar 11, 2003 | 07:19 PM
redteg's Avatar
Default Re: jrsc integra ls hp# (Jackson4Door)
sowhat should i do in my case i have a 1998 ls and from what you have said i won't make any power with the jrsc because it usesa m45 blower so what should i do.
Old Mar 11, 2003 | 07:20 PM
do more research.. dont just go and buy it thats all i can say..
Old Mar 11, 2003 | 07:21 PM
illi Adik's Avatar
Turbo mang! As its been stated before.
Old Mar 11, 2003 | 07:23 PM
redteg's Avatar
ihave been researching for 3 months now and since it is a daily driver that is why i choose to go with the jrsc. i have heard that turbosteups are a pain in the a**. the only good one ihave heard is the greddy setup. but i think i will have a higher chance of blowing my motor with a turbo
Old Mar 11, 2003 | 07:25 PM
bottlefedb18c1's Avatar
turbo is the way to go
that only what i think you can always go up but with the jrsc it will be hard to do that. you will never be happy with the hp
all i wanted before i odered my Gen 3 kit was 300hp at the crank now my new goals are 500-600 whp and i am almost there
just think about the future
Old Mar 11, 2003 | 07:26 PM
illi Adik's Avatar
Well man, Im saying, just get a good turbo kit, dont boost the fug out of it, and tune it and you will be fine. Tuning is everything, the Jackson isnt a save all for problems.
Old Mar 11, 2003 | 07:30 PM
redteg's Avatar
really i thought of that but didn't knoiw what to do but you don't think i can get 200 out of the jrsc. if i do go turbo ishould justgo with a greddy kit. i really want to try and make the jrsc work i feel i will have lessproblems with it to
Old Mar 11, 2003 | 07:37 PM
if you want a daily driven car greddy is the way to go....very little lag....
Old Mar 11, 2003 | 07:39 PM
redteg's Avatar
will i have problems with it
Old Mar 11, 2003 | 10:21 PM
greekspeed's Avatar
my sig has my numbers.....
Old Mar 11, 2003 | 10:56 PM
Boost2NA's Avatar
Default Re: jrsc integra ls hp# (greekspeed)
do not get this set up, do not. guy back home has a 98 civic with a LS motor and jrsc charger (along with all the basic bolt ons). His best run in the car is like a 14.9. For that much money he could of got a turbo and be running low 13s. JRSC for the LS is very weak, go turbo
Old Mar 11, 2003 | 11:07 PM
greekspeed's Avatar
Default Re: jrsc integra ls hp# (Boosted99Si)
well in my case i got everything (includiing fuel pump and 8 psi upgrade) for 1600...cant beet that price...
iw as gonna go turbo too but didn have money............ then i came upon this deal for the JRSC i have now.....
Old Mar 12, 2003 | 04:35 AM
GreddySi99's Avatar
THe ls motor is very strong when using the type-r blower (M62). It is very easy to modify it to fit. We installed on on a LS with over 180,000 miles on the engine and ran9PSI in a 92-95 hatch. It ran a 8.80 on 16" kumho 712's thats not to shabby I am sure it was making close to 200@the wheels. This was done with no electronics with the timing set @8degrees on pump 93oct. Hope that helps. If you need more info on what to modify email me @ Grand6000@aol.com Thank you
xXxDelSoulxXx
Feb 14, 2007 10:01 PM
supercivic B18B1
Apr 23, 2003 06:04 PM
redteg
Mar 15, 2003 09:31 PM
blackcracker
Sep 21, 2002 07:53 PM
OneThirtyEight
Jun 29, 2001 06:24 AM
