Jackson Racing supercharger noise?
Old Mar 7, 2003 | 07:49 AM
SIReg9's Avatar
Default Jackson Racing supercharger noise?
A friend of mine has a JRSC and it makes a sound similar to trasmision bearings goin bad. It doesnt sound good. But it was just refurbished by JR. Is this a common thing with them? Im just curious.
Old Mar 7, 2003 | 07:53 AM
falcongsr's Avatar
What is this crap?
Default Re: Jackson Racing supercharger noise? (SIReg9)
its probly normal. if there are problems with the gearing behind the pulley, that would be bad. but the thing makes some funny grinding noises during normal operation. when accelerating hard it should sound like a power drill on crack.
Old Mar 7, 2003 | 07:58 AM
BoostingSnail's Avatar
Default Re: Jackson Racing supercharger noise? (falconGSR)
yeah Im agreeing with falcon....its just probably the normal whine that comes from a roots type supercharger
Old Mar 7, 2003 | 10:11 AM
96IntegraRS's Avatar
Default Re: Jackson Racing supercharger noise? (BoostingSnail)
"but the thing makes some funny grinding noises during normal operation. when accelerating hard it should sound like a power drill on crack."
Exact description!!!
Gets quieter at idle when warm. Sounds great after a nice long drive.
Old Mar 7, 2003 | 12:20 PM
92sleepR's Avatar
New User
Mine makes some odd noises at idle but there isn't any play in it and it rotates like buttah. I think its just the normal eaton blower noise.
Mike
Old Mar 7, 2003 | 12:22 PM
metal-x's Avatar
Default Re: Jackson Racing supercharger noise? (92sleepR)
mines used to grind sometimes specially when it was cold out
Old Mar 7, 2003 | 12:45 PM
SIReg9's Avatar
Default Re: Jackson Racing supercharger noise? (metal-x)
Thanx for all the replies guys...I was just cusrious about the noise and it looks like its common. So no worries
Old Mar 7, 2003 | 06:43 PM
2000GSRT's Avatar
It sounds like the time machine from back to the future
Old Mar 8, 2003 | 12:35 PM
falcongsr's Avatar
What is this crap?
Default Re: Jackson Racing supercharger noise? (2000GSRT)
yeah! it does sorta sound like the funky sounds that Doc's delorean made...
Old May 21, 2004 | 06:42 PM
brent_G's Avatar
This is old but...mine makes a weird noise after i shut the ignition off. Like air is being squeezed out somewhere. Like a "skeeeeeeeerrtt" its weird.
Btw: just installed it havent had any time to mess with it since its started raining..but anyone have this problem? would vacum lines cause this noise?
Old May 21, 2004 | 10:16 PM
Muckman's Avatar
Moderator in Chief
Typical JRSC response: "Check the belts!" Those things stretch in a few thousand miles and make weird noises when they are loose (or too tight).
Old May 22, 2004 | 01:31 AM
brent_G's Avatar
Default Re: Jackson Racing supercharger noise? (Muckman)
yeah...its not the belts it just sounds like air gets trapped and needs to be pushed out. Like a whoopy cushion that doenst make the fart sound... hard to explain
Old Jun 1, 2005 | 11:44 PM
Jaker's Avatar
Default Re: Jackson Racing supercharger noise? (brent_G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brent_G &raquo;</TD></TR><TR><TD CLASS="quote">mine makes a weird noise after i shut the ignition off. Like air is being squeezed out somewhere. </TD></TR></TABLE>
That's a perfectly normal sound. Mine does the same thing. Just air that the blower was compressing when you shut off the motor.
Old Jun 2, 2005 | 01:27 AM
EnzoSpeed's Avatar
Default Re: Jackson Racing supercharger noise? (Jaker)
Mine makes a super high pitched whining noise, like a bad bearing, but only at a certain throttle position. And only when cruising.
It sounds like when you dip your finger in water and run it around the rim of a crystal glass, if you know what I'm referring to.
Old Jun 2, 2005 | 04:53 AM
1Bar GSR's Avatar
Default Re: Jackson Racing supercharger noise? (EnzoSpeed)
Sorry to go off subject but it is so interesting how all of yall describe the sounds that your supercharger is making its funny...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIReg9 &raquo;</TD></TR><TR><TD CLASS="quote">A friend of mine has a JRSC and it makes a sound similar to trasmision bearings goin bad. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSRT &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like the time machine from back to the future</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by falcongsr &raquo;</TD></TR><TR><TD CLASS="quote">when accelerating hard it should sound like a power drill on crack.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Mine makes a super high pitched whining noise, like a bad bearing, but only at a certain throttle position. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like when you dip your finger in water and run it around the rim of a crystal glass, if you know what I'm referring to.</TD></TR></TABLE>
Old Jun 2, 2005 | 08:45 AM
Honda_RN's Avatar
Default Re: Jackson Racing supercharger noise? (1Bar GSR)
damn I was about to say the same thing....haha can't we all agree on the same thing.. like it sounds like an electric screwdriver or something...
Old Jun 2, 2005 | 01:50 PM
EnzoSpeed's Avatar
Default Re: Jackson Racing supercharger noise? (Ringbearer020)
Well can all agree that it makes the Makita drill noise - that's under hard acceleration when your're boosting - that's normal.
I'm describing some other goofy noise it makes when I'm not boosting.
Old Jun 2, 2005 | 04:54 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Try google, I remember I found an article about that same thing that some guy had his rebuilt by JR and it was making terrible noises after and the JR guys were being complete dicks about it.
I would send it to Endyn, they can work some magic on those blowers!!
Old Jun 2, 2005 | 06:14 PM
EnzoSpeed's Avatar
Default Re: Jackson Racing supercharger noise? (2000psi)
Yeah, I don't know. Mine makes weird *** noises, but there's nothing at all wrong with it.
Old Mar 17, 2007 | 05:46 PM
kamciu80's Avatar
hey mine makes make a noise like the belt is squeaking but only when i step on it. is that normal. my boost gauge shows -20 ish neg pressure when crusing wit no acceleration . is that normal?? do i need a new belt if i change the pulley??
any help is great help guys thanx in advance.
Old Mar 17, 2007 | 11:52 PM
PickleTeg's Avatar
Default Re: Jackson Racing supercharger noise? (kamciu80)
Sounds perfectly normal to me and yes you will most likely need a different belt when changing to a different pulley.
EF Boy1231
May 30, 2008 06:22 AM
pli
Jan 21, 2007 06:33 PM
sir2k
May 19, 2003 07:41 AM
