Homade WG gaskets....what do ya think??
Old Mar 7, 2003 | 07:48 AM
Farnsrocket's Avatar
Default Homemade WG gaskets....what do ya think??
Well, after blowing out my Tial WG gaskets, I was bored and I decided to try and make my own. I bought a .025" aluminum sheet at Lowes and cut these out with my Dremel. I am wondering if the aluminum will hold up to the heat in the long run and thought I would get your opinions. I may try a steel sheet later if these don't hold up or may just buy some Firering gaskets if all else fails.
[Modified by Farnsrocket, 8:58 AM 3/7/2003]
Old Mar 7, 2003 | 07:53 AM
Smashback's Avatar
Default Re: Homade WG gaskets....what do ya think?? (Farnsrocket)
If they don't pan out use copper, best for exhaust gaskets
They look good though dude!
Old Mar 7, 2003 | 07:55 AM
PM-Performance's Avatar
Default Re: Homade WG gaskets....what do ya think?? (Hatchblack)
hahaha damn man is there anything you cant do
looks great , but do they seal better than tials **** ? i gav eup and dont even use a gasket anymore.
Old Mar 7, 2003 | 08:01 AM
MikeMAN's Avatar
Default Re: Homemade WG gaskets....what do ya think?? (Farnsrocket)
those shoudl work good! use some copper spray on them to take the extra pre-caution and then you shall be good to go! anything is possible with a dremel
mike
Old Mar 7, 2003 | 08:02 AM
Default Re: Homade WG gaskets....what do ya think?? (itr206)
Yeah, copper, I forgot about that.....I'll try that next. I have to put these on tonight, so I am not sure if they seal better or not. Before these, I used a thinner aluminum sheet and they sort of bent on me when I used a jigsaw to cut them out, so I don't think they were able to seal well. These are twice as thick and are perfectly flat thanks to the Dremel. I tried no gasket and it leaked a little. Well see. Thanks!!!
Old Mar 7, 2003 | 08:04 AM
I thought about copper spray.......wonder if it will burn off or just carbon up real nice and seal better?? I think I will use it. Thanks!
Old Mar 7, 2003 | 09:49 AM
Cramerox's Avatar
i bought some of these..i know its not cheap at 8 bucks each but i havent had any problems with mine.
http://www.roadraceengineering.com
Old Mar 7, 2003 | 10:28 AM
Evil EG's Avatar
Default Re: Homade WG gaskets....what do ya think?? (Cramerox)
That is what I use also.
Old Mar 7, 2003 | 11:20 AM
integranator's Avatar
Default Re: Homade WG gaskets....what do ya think?? (BVM)
is there anything wrong w/ tial's gaskets they include??
Old Mar 7, 2003 | 11:21 AM
BROOD's Avatar
Default Re: Homade WG gaskets....what do ya think?? (integranator)
They fail pretty easily, they look like the above gasket minus the compression ring
[Modified by SLPR, 12:23 PM 3/7/2003]
Old Mar 7, 2003 | 11:23 AM
CzanSOHC's Avatar
yea they are shitty paper/carbon gaskets that burn up real easy. I have went through 3 in only 350 miles.
Jon those look real nice...i was about to order 3 firering gaskets from RRE but now i might just make my own...awesome
Old Mar 7, 2003 | 11:34 AM
BoostedH23a1's Avatar
Default Re: Homade WG gaskets....what do ya think?? (CzanSOHC)
lol exatly the same thing we do.. they hold up fine..
Old Mar 7, 2003 | 11:37 AM
Default Re: Homade WG gaskets....what do ya think?? (BoostedH23a1)
So what do you think i should do?
Old Mar 7, 2003 | 11:43 AM
man go spend 7 dollars at lowes and make em.. u can get like 10 for 7 bux... then if u want order some from roadrace.. those are they better kind of gaskets.. TIAL ones that came with my friends kit sucks ***.. way too shitty.
Old Mar 7, 2003 | 11:55 AM
Thanks guys! Yeah, a 6" x 18" of .025" aluminum was under $7 at Lowes. I am sure I could get 10 gaskets out of it. If you look at the gasket at the top of my pic, that is the Tial and the black marks are where it burned through and just left the metal screen part of it......all the graphite stuff is gone.
Old Mar 7, 2003 | 01:00 PM
yea looks just like my friends.. i dont know what they were thinking.. roadraces ones are nice... i have some of those on mine.. but we made tin ones for my friend.. works like a champ
Old Mar 7, 2003 | 01:21 PM
Foozball26's Avatar
those turbonetics gaskets with the metal ring own all, you shouldnt blow them. So 10 bux and a very good seal and not having to replace it for a LONG time if ever.
[Modified by foozball-26, 4:22 PM 3/7/2003]
TypeSLO
Aug 7, 2006 01:28 PM
StolenTeg
Jan 9, 2006 02:38 PM
swlabhot
Nov 25, 2003 08:54 PM
r7
Sep 24, 2003 11:11 PM
RyanAutry
Apr 30, 2003 04:00 PM
