4WS Problem/Questions
Old Mar 6, 2003 | 12:24 AM
ophdehEEzY
Guest
Posts: n/a
Default 4WS Problem/Questions
Well, the 4WS light came on. Actually, it's been on for a while now. I just got too lazy to fix it until I saw another post related to 4WS.
Can anyone give me some troubleshooting tips to check up on whats wrong with my 4WS? Is there a way to jump the 4WS ECU? Should I check any loose connections running on a certain place? Is there some kinda oil or fluid I need to get it working? Any help would be.. well, helpful! Thanks in advance.
ophdeheezy
Old Mar 6, 2003 | 05:59 AM
Sephro's Avatar
Default Re: 4WS Problem/Questions (ophdeheezy)
you can pull a problem code for the 4WS the same way you do for the Check engine light. If you want to do that and you don't have a Helms let me know the code and I can tell you what it says. I would write it out but it is very long and just refers you to a certain chapter in the Helms.
Old Mar 6, 2003 | 10:43 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: 4WS Problem/Questions (Sephro)
the code the 4WS light is throwing is 71.
my 4WS hasnt been working for a few years.
[Modified by ophdeheezy, 11:49 AM 3/6/2003]
Old Mar 6, 2003 | 04:33 PM
yoshio006's Avatar
I got a 92 with 4WS..and I was wondering where the ecu for it is located? I have this big *** amp lookin thing mounted behind my drivers side back seat. I was wondering if it was an amp or soem sort of ecu?
thanks
Old Mar 6, 2003 | 08:42 PM
ophdehEEzY
Guest
Posts: n/a
Default Re: 4WS Problem/Questions (yoshio006)
anyone know what the "code 71" thrown by the 4WS light meant??
and yes, that is the 4WS ecu behind the rear seats.
Old Mar 6, 2003 | 09:16 PM
Quiklude's Avatar
code 71 Temporary driving conditions
"The car is driven aggressively with the driver and three passengers onboard, or the steering wheel is turned w/ the rear wheel blocked by the curb, etc."
quoted from my helms
Just reset the computer and see if it throws again
Old Mar 7, 2003 | 08:17 AM
ophdehEEzY
Guest
Posts: n/a
Default Re: 4WS Problem/Questions (Quiklude)
ok so it threw it again. any other suggestions? i have the feature of 4WS, and all the weight, but never got to enjoy it. My U-turns are wide as hell. AHH! Any advice anyone??
Old Mar 7, 2003 | 09:44 AM
Sephro's Avatar
Are you sure that your not getting any other codes than the 71? If your only throwing a code 71 your 4WS light should not be comming on at all. If you watch the 4WS light for a while does it just keep giving you the 7 long and 1 short flash? Watch it for about a minute to see if your getting anything else. Sometimes it can build up more than one instance of a code. For example it might throw a 71 3 times in a row then give you another code. I don't know why but the 4WS does this. Also if you keep watching the light you shoud have a pause for 1.6 secs then 3 seconds of rapid flashes. Then it will start throwing codes from the CPU's in the 4WS control unit. So I would check it again to make sure that you don't have any other codes.
JDMkid98ls
Oct 17, 2008 07:29 AM
JThrasher79
Dec 29, 2005 02:28 AM
wreckz
Jun 26, 2005 07:46 AM
Sam268
Sep 13, 2004 01:11 PM
NoLipRacen
Jan 29, 2003 11:27 PM
