check engine light help
Old Dec 26, 2005 | 08:33 PM
JThrasher79's Avatar
Default check engine light help
ok, i got a check engine light on my 95 ls but when i turn off the car and turn it on again it goes away so i cant check it. has anyone else had this problem? it comes on again after driving a little bit.
Old Dec 26, 2005 | 10:40 PM
typerhedlights's Avatar
Default Re: check engine light help (JThrasher79)
yea its normal. if you clear it will come back. it depends on how hard or faulty the code is. it will come back quickly after two full trip cycles. sometimes it can stay in the ecu memory due to monitors constantly sending feed back to your ecu. best bet is to find out whats wrong and fix it.
Old Dec 26, 2005 | 10:59 PM
jBj's Avatar
jBj
Default Re: check engine light help (typerhedlights)
Have you checked what code its throwing?
Old Dec 27, 2005 | 01:40 PM
Default Re: check engine light help (jBj)
thats the problem when i turn off the car the light goes away and i cant check it.
Old Dec 27, 2005 | 03:31 PM
find out what code it is and fix it.
Old Dec 27, 2005 | 09:23 PM
i CANT read the CODE it goes away when i turn off the car...
Old Dec 27, 2005 | 09:50 PM
djtony5's Avatar
Lol mannn..do you know how to check the cel code? Just turn off the car and jump the service connector located underneath the glove box compartment and then put in your key and turn it on to ignition or whatever. You don't have to turn on your car. Slow flash mean 10 and quick flash mean 1. So short short short short long equal to 41. G/l.
Old Dec 27, 2005 | 09:58 PM
civicdust's Avatar
Default Re: (djtony5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtony5 &raquo;</TD></TR><TR><TD CLASS="quote">Lol mannn..do you know how to check the cel code? Just turn off the car and jump the service connector located underneath the glove box compartment and then put in your key and turn it on to ignition or whatever. You don't have to turn on your car. Slow flash mean 10 and quick flash mean 1. So short short short short long equal to 41. G/l.</TD></TR></TABLE>
wrong its vice versa, if i remember, long are 10, and short are ones
Old Dec 27, 2005 | 11:48 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JThrasher79 &raquo;</TD></TR><TR><TD CLASS="quote">thats the problem when i turn off the car the light goes away and i cant check it.</TD></TR></TABLE>
Ok, you need the jump the green connector underneath your glove box with a paper clip or something, from one hole into the other. You then turn your ignition to the ON position, but dont turn the car on. Your CEL will flash, a long flash means 10, and short means 1. So if it flashes, long long short short = code 22.
It will flash over and over, so dont worry about gettin it right away.
Check this thread for the code ID.
https://honda-tech.com/zerothread?id=1171263
There is also a thread on team integra with a pic of your actual green connector, but i dont have time to find it right now.
gl
Old Dec 28, 2005 | 02:33 PM
im sorry if i made this confusing but after i get the light i turn off the car and i try to check it but the light gets cleared from the ecu when i turn it off or somthing so when i try to check it it gives me nothing.
Old Dec 28, 2005 | 10:20 PM
jBj's Avatar
jBj
Have you even tried pulling the code by jumping the connector??...or are you just not bothering because the light isnt always there..?
Old Dec 29, 2005 | 02:28 AM
i tried but it dosnt give a code. i know how to do it, its just not flashing.
slick jr
Jan 13, 2010 09:28 AM
NoLipRacen
Jan 29, 2003 11:27 PM
lilxvtecxpwr
Oct 13, 2002 11:04 PM
wadafa
11
Oct 3, 2002 03:49 PM
