CEL 10 and 41
Old Mar 5, 2003 | 02:49 PM
Hatch-E's Avatar
Default CEL 10 and 41
I've read in the Helms manual that the CEL 10 (IACV) and 41 (oxygen sensor) are for the d16z6. My car is throwing these two codes. (it's a 92 CX with a d16z6).
I've changed out the IACV but i still get the code. I've also resetted my ECu and also try another ecu but it sitll throws these two codes.
HELP ME. The CEL light is annoying!
Old Mar 5, 2003 | 03:40 PM
Hatch-E's Avatar
Default Re: CEL 10 and 41 (JDMhondaEH2)
help??
Old Mar 5, 2003 | 09:37 PM
Sasebonian's Avatar
I don't think that resetting the ecu works for these codes. I got 41 the other day, but it was because my O2 sensor wires/connectors fell against my DC header and melted halfway. I got the code when the sensor reached at certain temperature. Check your wiring harness near you header and see if the 4 wires are still good. Then if they are, you may have to replace the actually the O2 sensor. Online oem is like $150, honda direct oem I got quoted over $200. I got a used one from junkyard for $40. I haven't had any experience on code 10 thought.
Old Mar 5, 2003 | 09:51 PM
DOHCtorTHRUST's Avatar
Default Re: CEL 10 and 41 (Sasebonian)
are you still using the stock CX harness? if so thats your problem... the CX harness has a one wire o2 sensor and the d16z6(what ever z6,7,8) needs a 4 wire sensor. but that only applies if your using a p28 ECU
Old Mar 6, 2003 | 02:31 PM
Hatch-E's Avatar
Default Re: CEL 10 and 41 (DOHCtorTHRUST)
Nope. I'm using a EX harness that came with the engine. I know the O2 is bad and I have a replacement on the way as we speak. I'm just fed up with this damn CEL 10!! I've changed the thing that's wrong with 3 different IACV's and also changed out the ECU's. I've cleaned the connector and everything. I just don't know what else to do!!..
AHHHHHH!!!!!!
Old Mar 6, 2003 | 09:10 PM
try swtihcing the iavc's current connector with the sensor behind the TB, i always get them mixed up and they throw up codes.... try that one and i hope that helps....
Old Mar 12, 2003 | 09:40 AM
Hatch-E's Avatar
Could a Leaky Throttle Body gasket cause the CEL 10?
Old Mar 12, 2003 | 09:43 AM
prophet's Avatar
hey i got a 41 too. Are the o2 sensors interchangeble between the cat and the header (odb2 car)?
Old Mar 12, 2003 | 10:23 AM
Hatch-E's Avatar
Default Re: CEL 10 and 41 (prophet)
I think it should be interchangeable for any OBD2 O2 sensor, as long as the plugs match and it's obd2, it should work.
calvin924597
12
Jun 23, 2010 08:00 PM
king_pin
Mar 27, 2009 06:43 PM
busyychild
Sep 6, 2007 01:14 PM
GarageQueen213
Jan 31, 2002 06:00 AM
