problems with cel code 41
Old Mar 8, 2009 | 08:21 PM
king_pin's Avatar
Default problems with cel code 41
i have replace the primary sensor (new one) and the cel is still on
i try like 3 other sensor
anybody know how to get rid of the cel?
Old Mar 8, 2009 | 10:02 PM
Former User's Avatar
Default Re: problems with cel code 41
If you clear the ECU, does code 41 return? You probably have a problem with the O2 sensor wiring, though a less likely possibility is a bad ECU.
Old Mar 9, 2009 | 01:33 AM
king_pin's Avatar
how do i clear the ecu
my conversion harness wire is mess up
i pull some wires out so i gotta put it back together
Old Mar 9, 2009 | 12:04 PM
DRAMA's Avatar
clearing ECU = unplugging it from the car's harness (or just disconnect the battery with the computer still plugged in).
besides just changing out the O2 sensor, check the wires & ground signals
Old Mar 27, 2009 | 06:43 PM
egb16pg's Avatar
i had the same problem, my a/f sensor was bad. re placed it and the code went away.
fryguy190
Mar 16, 2008 10:21 PM
deftones0817
30
Sep 2, 2006 05:21 PM
undertheradar
Dec 4, 2004 08:03 AM
VTEC-DA
Jul 30, 2003 05:55 AM
GarageQueen213
Jan 31, 2002 06:00 AM
