CEL 10 and 41
CEL 10 and 41
I've read in the Helms manual that the CEL 10 (IACV) and 41 (oxygen sensor) are for the d16z6. My car is throwing these two codes. (it's a 92 CX with a d16z6).
I've changed out the IACV but i still get the code. I've also resetted my ECu and also try another ecu but it sitll throws these two codes.
HELP ME. The CEL light is annoying!
Re: CEL 10 and 41 (JDMhondaEH2)
I don't think that resetting the ecu works for these codes. I got 41 the other day, but it was because my O2 sensor wires/connectors fell against my DC header and melted halfway. I got the code when the sensor reached at certain temperature. Check your wiring harness near you header and see if the 4 wires are still good. Then if they are, you may have to replace the actually the O2 sensor. Online oem is like $150, honda direct oem I got quoted over $200. I got a used one from junkyard for $40. I haven't had any experience on code 10 thought.
Re: CEL 10 and 41 (Sasebonian)
are you still using the stock CX harness? if so thats your problem... the CX harness has a one wire o2 sensor and the d16z6(what ever z6,7,8) needs a 4 wire sensor. but that only applies if your using a p28 ECU
Re: CEL 10 and 41 (DOHCtorTHRUST)
Nope. I'm using a EX harness that came with the engine. I know the O2 is bad and I have a replacement on the way as we speak. I'm just fed up with this damn CEL 10!! I've changed the thing that's wrong with 3 different IACV's and also changed out the ECU's. I've cleaned the connector and everything. I just don't know what else to do!!..
AHHHHHH!!!!!!
AHHHHHH!!!!!!
try swtihcing the iavc's current connector with the sensor behind the TB, i always get them mixed up and they throw up codes.... try that one and i hope that helps....
GarageQueen213
01-31-2002 06:00 AM
