Head Studs???
Old Mar 5, 2003 | 10:16 AM
Convoy's Avatar
Default Head Studs???
I was wondering if when putting arp head studs are the steams suppose to be torqued to spec? i have a feelin that only the head studs were torque 64Nm not the steams. also can you re-use your stock head studs off the motor? cause i heard that after u pull them off they tend to stretch and u can't re-use them.
Old Mar 5, 2003 | 10:42 AM
TimoneX's Avatar
New User
Default Re: Head Studs??? (MiggytiMaestro)
I do not torque the stems into the block. I tighten them reasonably with a wrench then torque the nuts when the head is on. I've re-used head bolts, but I wouldn't re-use them too many times.
Old Mar 5, 2003 | 10:50 AM
Charlie Moua's Avatar
Default Re: Head Studs??? (TimoneX)
so how many times is the max for the re-used head bolts? 2-3 times?
Old Mar 5, 2003 | 11:04 AM
Convoy's Avatar
Default Re: Head Studs??? (Charlie Moua)
the apr's have been used like 5 times and my stock ones only once
Old Mar 5, 2003 | 01:02 PM
TimoneX's Avatar
New User
I've done 3x w/o any troubles. No sense pushing your luck too far, but I hate to throw money away too.
( o )( o )
Jun 2, 2012 04:13 AM
hYbRid_Eg6
Jan 26, 2012 10:00 PM
Incognito
Sep 18, 2009 12:52 PM
civicb18Tkid
May 3, 2007 07:30 AM
dumpeDc2
Nov 4, 2004 08:07 AM
