I can not believe it!!!!
Old Mar 4, 2003 | 03:48 PM
Comp97GSR's Avatar
Default I can not believe it!!!!
This past weekend I was getting ready to do a valve adjustment on the gsr and what do I find.... when the crank is at TDC the cams are advanced (toward the radiator) 1 tooth. The cams and gears are stock but the block was replaced by a local Acura dealer. Since I have got the car back it runs okay but seemed to lack in the top end where as before the car really shined. I suppose my question is, would my car run okay and get good gas milage if the gears where improperly aligned or did the head get milled and they didn't tell me about it??
Old Mar 4, 2003 | 05:17 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: I can not believe it!!!! (Comp97GSR)
Hmmm I'm not exactly sure on this one, but I think there is more than one mark on the crank pulley, mainly the TDC mark, and the stock 16 deg. BTDC timing mark. Make sure you're lining up the correct one (I don't know which one that is though, sorry).
Old Mar 4, 2003 | 05:20 PM
Comp97GSR's Avatar
Default Re: I can not believe it!!!! (PatrickGSR94)
I lined up the proper mark. Yes there are 3 marks you use for ignition timing (14/16/18) then there is the white mark for TDC.
Old Mar 4, 2003 | 08:35 PM
deepgreengsr's Avatar
if its one toothforward, wont the valves contact the piston?
TekBuDDy
Sep 21, 2018 03:28 AM
shesinmyroom
11
Jun 7, 2012 08:07 PM
APEX CRX
Sep 19, 2006 10:59 PM
1.7na
May 25, 2004 12:41 PM
echo999
Jun 9, 2002 07:39 PM
